One Key Door/Ignition
Old Jan 11, 2005 | 12:35 PM
Mark 42's Avatar
Mark 42
Originally Posted by SRD4X4
79-older are 1 key
80-91 had 2 keys
92-newer are 1 key (except glove box and bronco tailgates).
67-91 had a short key,
92-up is longer.
That seems to sum it up.
Old Jan 11, 2005 | 05:18 PM
SRD4X4's Avatar
SRD4X4
Just to add 1 more bit of confusion to this;Mid 84 Ford changed to a 10 cut key til 96,97 they went to an 8 cut key but retained the longer length.
Old Jan 11, 2005 | 10:31 PM
MemOrex's Avatar
MemOrex
I just remembered that my ignition is not the original. A couple years back, the truck wouldn't shut off, so a new ignition went in.
Old Jan 12, 2005 | 10:16 PM
1993F150XL's Avatar
1993F150XL
80-91 had 2 keys,79-older and 92-newer are 1 key (except glove box and bronco tailgates).67-91 had a short key,92-up is longer.I have key cut for my 90 ignition on 1 side and my 92 door/ignition on the other.I would think you could put 92-97 door lock in a 91-older and have 1 side cut for door and other side for ign.Hope this helps.
I have an 84 & an 85. Both are single-key.
Old Jan 15, 2005 | 12:11 PM
studerp's Avatar
studerp
Well this is strange. I have a 95 that has 2 keys, one for the doors and the other for the ignition. And they will not work any other way, as I have tried countless times to unlock the door with the ignition key or vice-versa. As far as I know it is all stock, but I can't guarentee it. It is very aggrivating that is for sure! :-)
Old Jan 16, 2005 | 06:40 PM
Mark 42's Avatar
Mark 42
Wil the "wrong" key even insert into the wrong lock?
Old Jan 17, 2005 | 12:18 PM
studerp's Avatar
studerp
Yeah either key will insert into either the door lock or the ignition, but only the correct one will make it turn. :-)
Old Jan 17, 2005 | 02:12 PM
Mark 42's Avatar
Mark 42
Is one square headed and the other round?
I've been wondering if the different pattern blanks
come in both head shapes.
The aquare headed one is a mirror opposite of the
round one on my truck.
Old Jan 17, 2005 | 02:49 PM
SRD4X4's Avatar
SRD4X4
Maybe the one's here who have 2 keys for 92-up,have 1 cut on both sides for doors and 1 cut on both sides for ign.Only 1 side of key should be required for door and 1 for ign. ( single key for both )?
Old Jan 17, 2005 | 03:46 PM
Mark 42's Avatar
Mark 42
Cool
I would do that if my key blanks weren't opposites.
My ignition key won't even insert into the door lock.
Old Jan 18, 2005 | 04:06 PM
studerp's Avatar
studerp
Both of mine are square head keys, and the cut is identical on both sides of each key. Now I will have to take them and get a key cut with one on each side and see if it works...........my curiosity is getting the better of me.
I assume with different cuts on each side of the key you would have to have it inserted "right side up (or down)" for it to work in either particular location? I didn't realize that the key only needed to be cut on one side to work I guess.
Old Jan 18, 2005 | 05:07 PM
Mark 42's Avatar
Mark 42
Yeah... there is only one set of tumblers, just like with a house key.
The "extra" side of the key dangles in space inside the lock cylinder.
It just makes it quicker and easier in the dark.
You could get your ignition re-keyed to maych the doors.
If you can take out the ignition lock and take it to a locksmith
it probably wouldn't cost much (It only takes him about 1/2 hour,
and if it's in his shop for $20 it'd be easy money).
Here's some info:
http://home.howstuffworks.com/lock.htm
http://home.howstuffworks.com/lock-picking11.htm
You could also take apart a door lock cylinder, measure the pins
in the tumbler, and get new pins at a locksmith for your ignition.
(if you can't rearrange and trim the existing ignition lock pins to
match the door pattern).
HRTKD
All Things Towing
Dec 25, 2016 05:14 PM
fordka
Ford Truck Parts for Sale
Oct 18, 2016 12:13 PM
hturner12
Apr 16, 2016 11:01 AM
884x4broncoII
Nov 28, 2015 07:23 PM
sdetweil
6.7L Power Stroke Diesel
Jul 20, 2015 03:02 PM
