Another Idle Question-'86 302
Old Nov 2, 2002 | 06:58 PM
fishingboy's Avatar
fishingboy
This is on a 1986 F150 w/302. With a warm engine, when I put the truck in park or neutral, or re-start a warm engine, the idle drops WAY LOW for 2-3 seconds, then comes back up. It idles fine in drive. I have cleaned the AIC valve. This is EFI. I also sprayed carb cleaner around the vacuum lines with no change. Any and all ideas will be explored, thanks. PS-the idle speed in neutral seems quite lower than it does in drive.
Old Nov 3, 2002 | 05:04 PM
steve83's Avatar
steve83
Check the IAC valve for carbon buildup & the servomotor for correct resistance. Also check the TPS and set it to 1.0V at idle. You can find all this in a Haynes manual ($12).
Old Nov 3, 2002 | 11:10 PM
Franklin2's Avatar
Franklin2
Also check the idle speed adjustment screw. To do this, unplug the idle air control solenoid wiring plug with the truck at idle. The truck should struggle a little, then die. If it cuts off right away, the idle adjustment is backed off too much. If the truck keeps running, the idle screw is screwed in too much.
Old Nov 4, 2002 | 05:54 AM
fishingboy's Avatar
fishingboy
Would u happen to know how to hook up a dwell/tach to this truck? It's not like my other vehicles that had a standard coil available to hook up to.......
Old Nov 4, 2002 | 07:31 AM
steve83's Avatar
steve83
Hook up to the E-core coil the same as the older ones. You may have to use different leads, but the connection is the same.
Old Nov 4, 2002 | 07:33 AM
steve83's Avatar
steve83
Old Nov 4, 2002 | 09:44 AM
fishingboy's Avatar
fishingboy
Well, I am not sure how to hook this up as this is my first Ford. Do I disconnect certain wires to do this? Thanks again.....
Old Nov 4, 2002 | 07:22 PM
steve83's Avatar
steve83
The Dwell/Tach should have some instructions (sometimes on a sticker on the back), but you probably just put it across the 2 coil terminals.
Get a Haynes manual and test the MAP, TPS, IAC... Heck, just check 'em ALL!
apemech
2004 - 2008 F150
Jun 26, 2013 11:51 AM
modracr62
Nov 21, 2007 09:56 AM
Dano1
May 16, 2005 10:56 PM
ccvmako
Sep 8, 2002 09:54 PM
wgm114
Feb 25, 2001 06:16 PM
