Rough idle with no load on engine
Old Nov 19, 2007 | 09:01 AM
modracr62's Avatar
modracr62
I have been trying to figure this rough idle out since i bought the truck and still can not figure it out. I have replaced the o'rings on the IPR and cleaned the EBPV tube and no codes are present. The truck will idle rough in park and neutral and when coming to a stop when the motor has no load on it it will "Romp Romp Romp" at a very fast pace but will stop as soon as the motor has a load on it. Sometimes i can fell in jerking the truck when coming to a stop. I am also having a very rough idle in park and neutral after it warms up that will go away when i put it in gear. When i put it in gear it idles up to 850 or so but when in park or neutral in will sometimes idle around 700. I also noticed when im driving and the T.C. is locked up it is very sensative at low rpms. Any one have any thoughts on what could be wrong..
Thanks for any help
TIM
Old Nov 19, 2007 | 09:16 AM
Action4478's Avatar
Action4478
Unplug the ICP sensor & see if it smoothes out , & while you are there , look to see if the sensor itself is leaking oil,, If it is , time for new....
Old Nov 19, 2007 | 11:34 AM
GeoffNJ's Avatar
GeoffNJ
I had a similar problem a few years ago. The ICP was fine so I put the HPX oil line on and it smoothed right out.
Check all the sensor stuff first and then try the HPX. I've heard that some of these trucks are just rough idlers.
Old Nov 19, 2007 | 11:53 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Both of these posts are in the correct area for your symptoms. Remember, the first thing to check is fresh proper oil. Then check for codes, then injector test, then you check for oil aeration. How long ago was the oring replacement on the IPR? Based on the post I would think it has been driven long enough to clear that out. Then we are looking squarely at the ICP. Don't forget about the IPR too.
Old Nov 19, 2007 | 11:56 AM
modracr62's Avatar
modracr62
Thanks guys...I will check the ICP today and let you all know what i find...
Old Nov 19, 2007 | 04:12 PM
TRICOMEDIC19's Avatar
TRICOMEDIC19
Man... ICP, IPR, HPX, IPP, What the hell does all that mean !!!???? :/
I also have a 2000 PSD and it is doing the exact same thing. I've cleaned the EBP tube and all that jive.. Yesterday, I noticed that while I was standing beside it with the hood up, I could hear a tapping sound coming from the drivers side.. It honestly sounded like someone tapping the top of a beer can with a screw driver. I leaned in and couldnt tell if it was the power steering pump or left bank.. The truck lost power about 5 months ago... I'm at a loss and damn near ready to take it to the STEELERSHIP for one of those $300.00 dollar tests that wont reveal a damn thing.
Old Nov 19, 2007 | 05:19 PM
Action4478's Avatar
Action4478
Your best bet would be start a new thread, list some info about your truck ,when the problem started ,& were you fixing anything at the time
These guys will get it figured out
Acronyms ....here.....
Scroll down....
Old Nov 21, 2007 | 07:33 AM
modracr62's Avatar
modracr62
Ok...I unplugged the ICP and it solved almost everything. Im guessing i need to replace it? Thanks for all your help.
Tim
Old Nov 21, 2007 | 08:35 AM
TRICOMEDIC19
ok.. what is that and where is the plug so I can try that myself? When you unplugged it, what did it sound like afterwards?
Old Nov 21, 2007 | 09:48 AM
modracr62's Avatar
modracr62
Cool
The ICP is on top of the drivers side head toward the front. I waited for my truck to start idling rough then unplugged it and it idled perfect and then drove it and it didnt have much power but it cured all of my problems except the one that the stearlership caused this morning....195.00 for the IPC....
Old Nov 21, 2007 | 09:53 AM
TRICOMEDIC19
hmmm.. I've unplugged that connector before and it THEN started running like hell.. and made no improvement.. I wonder how I would know if it's bad too??
$195.00 for the ICP ?? Thats crazy !! Autozone didnt have it?
Old Nov 21, 2007 | 09:56 AM
santacruzf250's Avatar
santacruzf250
Look for a OEM ICP on ebay, you'll get one for much cheaper. I purchase almost all my OEM parts on ebay for fractions of dealer cost.
nossliw
29
Feb 23, 2015 12:56 PM
CrewCabLongbox
28
Sep 17, 2014 12:54 PM
BrentElliott0093
1997 - 2003 F150
Apr 14, 2014 05:33 PM
strokersace
Jan 17, 2010 12:36 AM
toddnga2002
Mar 29, 2003 04:25 PM
