will this tranny fit?????
Old Oct 31, 2002 | 10:58 AM
Whitey078's Avatar
Whitey078
i have an 85 f-150 4 speed (with granny gear) 4x4. i think i may have hurt the transmission cause it maeks noise and have 3 speeds is irritating in and of itself, i have the opportunity to buy the following trans
88 FORD 5SPD TRANS, 4WD, standard, straight from 6 cyl motor for 150 pickup or Bronco
will it fit in my truck? and if so what would i have to do to get it to work, do i have to change the clutch? the driveshafts the bell housing what?
also how would this effect my towing ability, my truck SUCKS on the highway so i'm thinking that the 5 speed may help that and if it's a direct bolt in that would be great as well, but i dont' know if this has a granyn gear or at least somethign approaching one (i do tow pretty decent sized loads from time to time
Old Oct 31, 2002 | 07:16 PM
Ford_Six's Avatar
Ford_Six
it'd work great if you change your t-case too. I think that after 86, they used different splines on the input.
Jared
Old Nov 3, 2002 | 05:27 PM
steve83's Avatar
steve83
Same splines & mounting bolt pattern for all '80-96 t-cases in all F-Series & Bronco. It's a bolt-in except you may have to move your crossmember forward/backward and have your driveshafts shortened/lengthened. You may also have to change your floorplate adapter for the shifter location.
Old Nov 4, 2002 | 02:56 AM
Brian460's Avatar
Brian460
When you say your truck sucks on the highway what do you mean? If it already lacks power then a 5th gear OD will not help that at all.
Old Nov 6, 2002 | 10:01 PM
Ford_Six's Avatar
Ford_Six
Old Nov 7, 2002 | 01:58 PM
Whitey078's Avatar
Whitey078
i mean i tlacks power. the problem is that with eh granyn gear i have a 3 speed basically, so at 50-65 mph the rpms are too slow to have enough power to keep speed up even a slight hill (75 mph is better) and it's too high for 2nd gear. a 5 speed will ahve closer gear ratios than my 3 speed
Robert Hudson
Aug 17, 2012 05:09 PM
Torchin' an Truckin'
Jul 19, 2010 09:42 AM
pete17c
15
Feb 19, 2010 02:42 PM
wildstang
Sep 17, 2008 07:56 AM
