idle probs
Old Nov 7, 2002 | 06:52 AM
78bronco's Avatar
78bronco
idle probs
my 84 351w idles good when cold at a stoplight but when warmed up a little it sputters and comes close to dieing. its around 30*F here in the morning.
Old Nov 7, 2002 | 05:31 PM
steve83's Avatar
steve83
idle probs
Make sure the choke isn't staying closed. Next time it does it, pull into a parking lot, pull the air filter cover, & look down the carb. If the choke plate is even partially closed (the one at the top of the carb), then you need to adjust it &/or tune-up/rebuild/replace the carb.
Old Nov 7, 2002 | 08:32 PM
78bronco's Avatar
78bronco
idle probs
the choke works, i had it idleing in my driveway for 5-7 minutes b4 it opened fully.
Old Nov 8, 2002 | 10:33 AM
Ford_Six's Avatar
Ford_Six
idle probs
