Transmission
Old Nov 6, 2002 | 09:54 PM
Last2Know1's Avatar
Last2Know1
Transmission
while driving going up the gears the ride is for the most part pretty smooth. while in overdrive and going to pass another car it drops into passing gear and i get a like.... oumph. how do I fix this problem. I allready drained and replaces the fluid. any help will be appericated
Old Nov 6, 2002 | 10:57 PM
steve83's Avatar
steve83
Transmission
First, you should tell us what kind of transmission you're asking about, or at least the exact vehicle it's in!
The general answer is: have it serviced, & adjust the bands. A Haynes manual tells how.
Old Nov 6, 2002 | 11:10 PM
Last2Know1's Avatar
Last2Know1
Transmission
I believe it is a c-6 trans it is in a F-150 with AOD with a EFI 302
Old Nov 6, 2002 | 11:44 PM
Ford_Six's Avatar
Ford_Six
Transmission
it's an AOD, not a C6. Does the motor rev up and "slam" the passing gear, or does it just hit real hard?
Jared
Old Nov 7, 2002 | 06:10 PM
Last2Know1's Avatar
Last2Know1
Transmission
[updated:LAST EDITED ON 07-Nov-02 AT 07:10 PM (EST)]no it does not rev than slam its like a quick jerk.
but it does hit , well i think hard
Old Nov 8, 2002 | 10:33 AM
Ford_Six's Avatar
Ford_Six
Transmission
If it slams into second or third gear while accelerating, it's a broken accumultor spring. If not, just drive it. It shouldn't damage the tranny. If it gets worse, I'd go to a trans shop for a second oppion.
Jared
Old Nov 8, 2002 | 10:39 AM
Ford_Six's Avatar
Ford_Six
Transmission
