8.8 gears
Old Jan 9, 2005 | 05:02 PM
Brnco85's Avatar
Brnco85
8.8 gears
I'm doing work on my 8.8 Bronco rear end and I want to put in a locker. it currently has the original 3.55 gears and I was just wondering if I have to have both gears and a locker or just one or the other, because I was also looking at putting in 4.10 gears but wasn't sure weather i need to put in both or with a locker act as the gears? I am confused on how it works please help.
P.S. does anyone know how many splines my rear end has? it's an 85 Bronco with an 8.8, all original rear end. I know its either 31 or 28 and am just hoping I can find out without taking it apart and counting lol. thanks
<!-- / message -->
Old Jan 9, 2005 | 10:41 PM
f100beatertruck's Avatar
f100beatertruck
A locker is a traction device, gears get the truck moving. (basically) You can change to 4.10's and use the same carrier that the 3.55's are on. You can also put a locking carrier (locker) in with the 3.55 gears, but I'd get new gears. The rear should be 31 spline. My 86 F150 and 89 Bronco both were 31 spline. Cars are 28.
You'll also have to change the gears in the front too. You also need a new carrier for the front because they have two types, up to 3.73 and 3.90 and up. I saw an ad in 4 Wheeler mag for a dana limited slip for $200. You can get just an empty carrier and reuse your old spider gears too. It's about $60.
You'll also need bearings and seals and someone who knows how to put it togeather.
Hope this helps.
David -
Old Jan 9, 2005 | 11:19 PM
Brnco85's Avatar
Brnco85
thanks
hey thanks for the advice david its been helpful. im a technician in training and am new to all this stuff but thanks for your help.
dakota-boy
Jan 2, 2011 10:18 PM
m8094538
Feb 12, 2010 08:26 PM
Brnco85
Jan 9, 2005 09:03 PM
killowatt
1997 - 2003 F150
Jul 11, 2004 02:17 AM
bigdooky
1978 - 1996 Big Bronco
Nov 6, 2002 06:43 PM
