Homemade code reader/test light?
Old Nov 6, 2002 | 06:28 AM
danzaid's Avatar
danzaid
Hi,
Does anyone have a link to a homemade test light? Yes I am a complete cheapskate! I don't own an analog meter or I'd probably stick with that.
TIA,
Dan
Old Nov 6, 2002 | 12:28 PM
Ford_Six's Avatar
Ford_Six
How cheap can you get? A test light is around$5, and Radio Shack has a pocket digital multimeter for $25.
Jared
Old Nov 6, 2002 | 02:23 PM
Franklin2's Avatar
Franklin2
I assume you know about how to read the codes with a analog voltmeter since you already mentioned it.
Really, a decent analog meter would be a good investment. If falls short as far as testing components and some of the circuitry on a computerized vehicle, but you can't beat it for testing lighting circuits and other regular circuits in an auto. If you get one with the higher voltage ratings, you can use it in your house too, for stuff like water heater element checking, and double checking circuits to see if they are safe, such as installing a ceiling fan or something.
Old Nov 6, 2002 | 06:09 PM
steve83's Avatar
steve83
You don't need anything to read codes on '87-95, and maybe a 12V test light on older EFIs. The engine light on the dash will flash the codes out - all you have to have is a jumper wire (paperclip) and the code list.
http://www.broncodata.com/tech/codes.htm
Old Nov 7, 2002 | 07:13 PM
danzaid's Avatar
danzaid
I'm sorry I do own a DMM, but they can't compare to an analog's sweeping hand, which is better for this process of counting pulses. I guess I should buy the light, but I'm fond of making test jigs and the like. I just thought someone had a schematic for a test light. Thanks for the info all the same. My truck is an '86, but I'll look for the engine light and see if it does anything while I'm at it.
Dan
Old Nov 7, 2002 | 11:44 PM
steve83's Avatar
steve83
'86 doesn't have an ENGINE light. You'll have to hook up something that detects a 12V pulse; either a light or meter.
Old Nov 8, 2002 | 06:36 PM
danzaid's Avatar
danzaid
Thanks Steve.
I just got a 12 volt light. Also picked up the Hayes for the Bronco, F series etc. I dare say it's more thorough than the Chilton with respect to electrical info.
Thanks again,
Dan
PS, any insight on what a good culprit for NO advanced timing may be? I'm gonna swap the whole distributor, TFI combo for a known good. Also have a spare computer. Thank You.
Old Nov 8, 2002 | 08:04 PM
Franklin2's Avatar
Franklin2
Follow the distributor wires back in the harness. There is a spout connector that may be unplugged. You have to unplug this to set the timing, but maybe somebody unplugged it by accident. This would give you no advance.
Old Nov 8, 2002 | 08:59 PM
madmacs's Avatar
madmacs
bcampbell06
Jan 17, 2014 09:25 PM
ItsAFord55
Appearance & Dress-Up
Jun 21, 2011 11:47 AM
clintbonnie
May 21, 2011 06:38 PM
Monsta
Modular V10 (6.8l)
24
Feb 4, 2006 02:04 AM
mgman
Offroad & 4x4
Mar 8, 2005 09:05 PM
