Bronco II Ford Bronco II
emergency brake
Old Jan 9, 2005 | 11:52 AM
jakes29's Avatar
jakes29
emergency brake
87 bII. okay, I had a brain fart. It has been really cold here, in the lower twenty's with lots of ice. Out of stupidity I set my emergency brake and it froze. Now it will not release. Has anyone else had this problem? What is the best way to get it unstuck? Should I just leave it until it warms up?
Any advice as always is appreciated!
Old Jan 9, 2005 | 01:02 PM
Ken00's Avatar
Ken00
Sometimes it will break loose when backing up, maybe a hairdryer would help from the back side.
Old Jan 9, 2005 | 11:02 PM
wicky's Avatar
wicky
I had the same prob when I replaced the brakes when I got mine. The Parking Brea kwas STUUUCK! So I cut it off the cable, bad idea. Gotta leave it gear when I park.
Old Jan 10, 2005 | 06:01 PM
rebocardo's Avatar
rebocardo
You should always leave a vehicle in gear when parked unless it is a tractor (trailer). The brakes on the BII are not strong/big enough to prevent the BII from rolling downhill on a steep incline.
Best way to get it unstuck is to just run the vehicle, the exhaust will melt the ice on the cables, especially if you are in snow and it is piled around the sides. Otherwise crawl under the vehicle and pull the cables down and snap them against the body. You need a stick to do this. Or just knock it off with a hammer.
royeco
Nov 20, 2016 07:39 PM
HILLBILLY BOB
Aug 21, 2015 02:37 PM
deerdude
Apr 14, 2008 01:54 PM
SasquatchF-250
Jan 31, 2006 10:47 PM
RetiredPig
Sep 10, 2005 09:45 AM
