Waxing truck, what do I need
Originally Posted by fordguy21
Only thing about waxing our trucks is that you have to becareful not to get wax on you plastic trim peices because it is almost impossible to get off.
originally posted by RyanMiller
I bought some meguiars wax in a little can, and applied that on the truck, let it dry till it was foggy, and buffed it out by hand with a terry cloth thing. It came out great!
Chris
Originally Posted by 1BadF150
Meguiars and zymol are auto zone waxes... you want the good stuff? go here http://www.zainostore.com/Merchant2/merchant.mvc and go to "product info"
thanks for the link!
a good forum for car care is http://autopia.org/forums/
Ryan: Visit their website at meguiars.com. They offer a free service called the paint rx in which you answer some broad questions about your truck and they respond with their proper products to produce the desired result. I have used their products for 40 years - consistently good stuff. Beeboy mentioned autopia.com - that is also a good forum and he is also correct about keeping the angle grinder away from your paint. To an untrained hand, it is real easy to burn through your paint job.
The orbital polishers with the thick foam pads work reasonably well and are bullet-proof as far as burning your paint. It will save your arm when using it to apply your product of choice.
Recently purchased a Porter Cable 7424 random orbit machine which was on sale from Amazon.com. I then needed to purchase a variety of pads - cutter, polisher, one to apply the final coat and a buffer pad. This machine is awesome and fast. It used to take me about 1 1/2 hours to clean up one of our Rangers and now it is about 40 minutes. I try to do this each time they are in for service so they look good. We use Granitize products - I use a silicone-free cleaner - windows and everything - followed by their polymer wetcoat which holds up very well. I have never seen this stuff on the shelf in a parts store but one can get it from the mfg. at their website.
Good luck.
Russ
Good luck.
Russ
Meguairs is the way to go its good stuff. Stay away from the buffer unless you have some thing to pratic on first. once you burn a hole in the paint your screwed. use the wax/cleaner stuff it works good and you only have one step not two. I use that at home. but at work I use some other stuuf but I put it on with a buffer and theres three steps to it. Just make sure your truck is clean. you can also use silcon dressing on all the plastic parts to clean them up.
Blitz Wax
There are many products out there, but I would recommend One Grand's products (search for onegrand in any search engine com). They have been in business since 1933, but are not well known because they have mostly marketed to professional detail shops, not the "average joe". They make one of the best carnauba waxes around, and at a price everyone can afford, too.
For the absolute best wax job, be sure you use both a glaze or polish and then the wax. Most people just wash and wax, but use the polish first and you wont believe the difference. I did it for my dad's old '69 Ranger with the original black paint, and even though his paint is almost worn through in places, etc.. it looked better and had a deeper shine than any car Ive ever seen on the lot.
I dont have any pics to share, but you can check out the 'Testimonial' section of their site, and see what kind of a look you can get with it.
Another thing.. in this day of multi-national corporations, they are still a family run business, and are willing to take the time to answer any questions you have about the products or how to use them.
