351 Id
Old Jan 8, 2005 | 02:24 AM
rig_pig30's Avatar
rig_pig30
351 Id
I Have A 1986 F350 Van With What Is Sapose To Be A 351m But Not To Sure . These Are The # I Got Off The Block By The Starter. D4ae-6015-aa7. Any Help Would Be Much Apretated.
Old Jan 8, 2005 | 07:56 AM
mark a.'s Avatar
mark a.
I think '82 was the last year for the 351m. I know it was gone before '86.
Old Jan 8, 2005 | 12:15 PM
grclark351's Avatar
grclark351
engine usage might've been different in canada, the easiest way to tell the difference between the W and M is to look at the exhaust manifold bolts. they are in a straight line on a W and they are on a diagonals on an M.
Old Jan 9, 2005 | 12:58 AM
Bill_Beyer's Avatar
Bill_Beyer
D4AE is a legitimate casting code for a 400 engine and since they're the same block it's possible it's a 351M but very unlikely. I seriously doubt that they continued the 351M in Canada after it was phased out in the states. Even if the engine is stock it should've been a DxTE casting since it's in a truck. It's almost certainly a 351W. Check to see if the thermostat housing goes into the intake manifold or the block. If it goes into the manifold then it's a W.
Old Jan 9, 2005 | 02:35 AM
rig_pig30's Avatar
rig_pig30
ok thanks i will check those things out and let yous know what i come up with.
if this helps any. its an 1986 f350 school bus(van stile, on propane)
ola1234
Mar 17, 2017 08:36 AM
BAKAFLAKA
Engine Swaps
Oct 13, 2015 12:12 PM
Bud Mud
Jul 17, 2014 07:15 AM
marcoelam
Jul 11, 2014 02:29 PM
Tinterat
Apr 18, 2014 02:17 PM
