Air Bag Code 52
Old Jan 7, 2005 | 08:00 PM
Tptoe's Avatar
Tptoe
Air Bag Code 52
I have this code on my '98 Expy. How do I fix it ?
I believe it is for a faulty "backup power supply voltage bost fault"
thanks
Old Jan 11, 2005 | 02:05 AM
dmvguy's Avatar
dmvguy
Airbag Code 52
The same code just popped up today on my all stock 98 Expy EB with 118,000 miles. My speedodometer also stopped working today. Nice timing as we are in the middle of the worst snow storm, in Carson City, NV, since 1912. Since I have had no major problems, that have cost me money, in the two years since I bought the rig I am going to take it to the local Ford dealer and let them fix both problems. My dealer gives me a 1 year/12,000 miles on any work done except normal maintenance. I really enjoy my Expy and like to keep it in tip top running condition.
Old Jan 11, 2005 | 11:51 AM
Tptoe's Avatar
Tptoe
dmvguy:
I'm from Buffalo, NY .. and sure I know what snow is all about. Glad you have a good truck for the snow.
If you gain any info from the dealer on the airbag code please post here.
Take care
Old Jan 11, 2005 | 07:43 PM
dmvguy's Avatar
dmvguy
Dealer action on Airbag code 52
Hey Tptoe and other interested parties,
The dealer found a blown fuse caused by moisture. The blown fuse causes the low voltage code. They replaced the fuse and reset the codes and it is working fine now. It was worth the labor cost to learn what the problem was and how to fix it as well as learning that here were no other problems with the airbags components. It will most likely happen again especially during the winter season. Check your fuse first. Replace if necessary and then have Autozone reset your codes. If it is not the fuse then I would recommend taking it to your local Ford dealer.
Old Jan 11, 2005 | 08:51 PM
Tptoe's Avatar
Tptoe
dmvguy:
Two questions:
1. Where is the fuse located?
2. What does resetting the code do .. does it just shut off the blinking light on the dash ?
Thanks !
Old Jan 12, 2005 | 04:21 PM
dmvguy's Avatar
dmvguy
Fuse panel is under the drivers side of the instrument panel behind the fuse panel cover.
There is a power distribution box on the left inner fenderwell in the engine compartment that has fusible links and fuses.
I do not know which of these contains the airbag fuse.
If it is not reset the airbag light will continue to blink or stay on.
98 EB Expedition
5.4 Triton
Red and Tan
118,000 miles
all stock
Bluebomber94
Nov 11, 2017 10:20 PM
kbf1961
Oct 17, 2015 10:05 PM
trucktech
Jul 12, 2012 02:09 PM
IM1096
Mar 29, 2007 09:02 PM
swunderle
Escape & Escape Hybrid
Nov 7, 2004 03:59 PM
