6.0 Surging And Stalling
Old Jan 12, 2005 | 12:31 PM
moebdick's Avatar
moebdick
Originally Posted by moebdick
My '04 F250 with a March '03 engine build date
Sorry, that should be March '04 engine build date.
Old Jan 21, 2005 | 02:55 AM
facatalani's Avatar
facatalani
Cool
I've had the same problem since new in June '04. Engine chugs then dies at idle, surges thru takeoff and surges at constant speeds of 40 - 60 mph. It's at the dealer now for the 4th time. Thus far, EFT valve has been replaced. Engine and transmission sensors have been reset/replaced. Loose connections have been restored. This time, the engine wiring harness is being replaced. Through the first 9900 miles, this 6.0 has been a huge pain although when it's not surging or stalling, it runs and pulls great.
Old Jan 21, 2005 | 06:50 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Click here:
https://www.ford-trucks.com/forums/s...d.php?t=325000
We are pleased you have chosen the best source for Fords!
See you on the boards.
Enjoy FTE …..
Old Jan 21, 2005 | 10:03 AM
okeefl's Avatar
okeefl
I had the exact symptoms described in the first post. Truck had reflash done with no change in symptoms. I solved mine by lowering the oil level to just above the minimum mark. That was 6 months ago and to date I have not had the problem reoccur...knock on wood!
SNIPER168308
Jan 1, 2016 03:34 PM
cajunsuperduty
Oct 28, 2011 03:31 PM
SlipGear
Jan 6, 2010 11:07 AM
spinge
Dec 19, 2009 11:34 AM
bgraham
Feb 11, 2004 07:52 PM
