brake rotors
Old Nov 21, 2002 | 01:23 PM
YWAMNick82f150's Avatar
YWAMNick82f150
brake rotors
i need new brake rotors for my '82 F150 4x4, my question is, are they one piece hub and rotor, or does the rotor separate from the hub? i need to know so i can get the right part at the store
Old Nov 21, 2002 | 02:14 PM
RockyMtnF250's Avatar
RockyMtnF250
brake rotors
Remove the hub and rotor from the truck, press out the wheel studs and the hub and rotor will separate. To reinstall line up the stud splines where the will engage into the hub as they were before, place the rotor onto the studs and hub and seat by tightening the lug nuts with the flat side down, you may need to use some washers to take up the non-threaded space on the studs. I have done this using a block of wood and a hammer to knock out studs and then seating everything by tightening the wheel back onto the hub and rotor assembly, be careful not to damage wheel.
Wes
Old Nov 21, 2002 | 06:11 PM
MagBayBrian's Avatar
MagBayBrian
brake rotors
[updated:LAST EDITED ON 21-Nov-02 AT 07:11 PM (EST)]>i need new brake rotors for my '82 F150 4x4, my question is,
>from the hub?...
You can buy the rotor seperate from the hubs, and have the old rotors pressed off, and the new rotors pressed on. Then you need to to have the rotors turned to make sure the whole assembly is true.
I found that buying a hub rotor combo actually was $10 cheaper than paying all the machine shop costs for new rotors only.
85 F150 4x4, Bal & BP 302, EFI, K&N air filter, Heddman headers, High-flow Cats, Custom side-exit exhaust, 4" Rancho lift, Rancho 9000 shocks, Rancho Torque Arms, 4.10:1 gears, Rear limited slip diff., 33" BFGs, Warn Winch, SnugTop.
Old Nov 21, 2002 | 07:59 PM
YWAMNick82f150
brake rotors
thanks, i priced hub/rotor combos at autozone, and they were only about $30 a piece, i just wondered if thats the best way to go, which sounds like it is
Nick Stewart 1982 Ford F150 4x4 aka "the tank"
pray for the peace in Jerusalem
Old Nov 21, 2002 | 11:13 PM
Tetchy101's Avatar
Tetchy101
brake rotors
Newenglandfordjunkie
Aug 12, 2013 11:02 PM
wicat3
Sep 15, 2012 02:30 PM
duct tape F-150
Aug 1, 2011 08:03 PM
danlee
Apr 5, 2008 12:03 PM
rick8637
1997 - 2003 F150
Jun 13, 2005 05:43 PM
