needing a diagram or pics of the distributor in a 1984 f-150 ...or info on installing ,, need to know which post on the cap is #1.. and also the postion of the dizzy it's self ...
Just bring #1 up to tdc on compression - install the dist, note where the rotor is pointed and make that #1. put the plug wires on in order. Not to hard really.
usually - the rotor is pointed away fron the engine block for #1, but so long as th rotor is timesd to the correct cyl - it really won't matter much.
Your timing is too late that accounts for the overheated exhaust. If you can't get
the timing right move the distributor one tooth and try again. If the distributor doesn't
go in all the way just turn the engine over and it will rotate enough to index with the
oil pump and drop in.
