ranger fender
Old Jan 7, 2005 | 03:05 AM
rocketroy's Avatar
rocketroy
ranger fender
hi all, just got my 88 ranger back after a clutch job and low and behold
some one wacked it on the drivers side fender right where the mud flap meets the body work.
how hard is it to get the fender off?
whats holding it on,besides the bolts i see along the top when the hoods open?
if it take it off am i going to be able to bang it from the inside, or does it have more than one layer of metal.
i need to put the crease back in it where it goes behind the wheel to the point where the mud flap is attached!
Old Jan 11, 2005 | 07:31 PM
87ford4x4inline6's Avatar
87ford4x4inline6
Besides the bolts along the top there are 2 behind the grill on the side and 2 under the front, and 2 in the rear through the door jam. 1 under the door on the bottom of the rockers. then there are the ones holding the finder skirt in place. This will get the outer fendar off. the inner fender is spot welded but you shouldnt have to remove it. depending on how deep and where the dent is. you may be able to get most of it out.
emd160
6.7L Power Stroke Diesel
Jun 13, 2011 03:23 PM
trout08
1983 - 2012 Ranger & B-Series
Apr 4, 2008 04:16 AM
polarisman
Nov 16, 2007 05:43 PM
mwpierson
Apr 26, 2005 07:49 AM
Nalow
Mar 12, 2004 02:57 PM
