88 f150, pulling codes
Old Jan 6, 2005 | 11:33 PM
chrono4's Avatar
chrono4
ive looked all over in the wiring harness on my 88 f150 for the plug im suppose to ground out to pull the codes.i got almost every electrical thing workin and now i want to pull the codes and see what im getting that c.e. light for, cause shes running kinda rough. to test it with a scanner, would i still need that plug? any other way to do it? also, does anyone know what color that cable is? thanks
drew
Old Jan 7, 2005 | 07:16 AM
EPNCSU2006's Avatar
EPNCSU2006
You need the diagnostic port to get codes, with a scanner or not. It should be near the air filter housing on the drivers side fender, maybe even attached to the bracket on the airbox with the relays. The STI wire is white with a red tracer, STO is pink/lt green, fuel pump test is tan/lt green, and signal return is black/white.
Old Jan 7, 2005 | 03:22 PM
chrono4's Avatar
chrono4
so i have to have the one single wire?
Old Jan 8, 2005 | 07:10 AM
EPNCSU2006's Avatar
EPNCSU2006
Yes, it's the one that you have to short to signal return.
zeroo
6.7L Power Stroke Diesel
Jun 29, 2021 12:32 PM
stevenjf88
Jun 16, 2015 08:03 PM
th3Whip
1997 - 2003 F150
Feb 6, 2012 02:02 PM
medic5100
Oct 7, 2007 10:23 AM
SSC
Jan 9, 2003 04:58 PM
