mystery engine
Old Jan 6, 2005 | 09:25 PM
4x4man514's Avatar
4x4man514
mystery engine
hey guys,i dont know anything about the fe motors but i recently inherited a 76 f250 and i dont know whats in it.i read somewhere that the 352 stamped on it doesnt mean anything.does it even mean it is a FE motor?one thing i noticed that ive never seen on a ford motor is that the water pump is set off the block like a chebby.how can i tell what i got?thanks guys.
Old Jan 6, 2005 | 09:43 PM
jstandle's Avatar
jstandle
Does the intake go under the valve covers a little ways? That would indicate an FE.
Do you have a VIN # for the pickup? We could look at that and see what motor it had when new, and possibly still has.
Old Jan 6, 2005 | 09:46 PM
gtex's Avatar
gtex
well, the 352 indicates you have an FE engine. Being a 76, odds are you have a 360 or a 390 in a truck. Other FEs possible, if somebody did a swap. I don't thin 428s were still being used in 76.
If you think or know it's original, the VIN number will ID your engine.
All that aside. The best way to determine what you have is measure the stroke or ID the crank. Cheak out the FAQ in this forum for some useful info on FE engines.
Old Jan 6, 2005 | 10:55 PM
ford390gashog's Avatar
ford390gashog
get the date codes and casting numbers
Old Jan 7, 2005 | 12:39 AM
4x4man514's Avatar
4x4man514
thanks guys,im not sure if the motor is original or not so i dont know if the vin # will help or not.i dont have the truck handy right now anyways.if the # dont help,is there anyway to tell with the motor still in the truck?any external casting #S?thanks
Old Jan 7, 2005 | 02:22 AM
ford390gashog
only the dowl test
Old Jan 7, 2005 | 02:34 AM
4x4man514's Avatar
4x4man514
thanks ,i just read about that.3.5=360 and 3.75=390.can i use that test to determine any of the other fe motors?
Old Jan 7, 2005 | 08:49 AM
gtex's Avatar
gtex
the stroke will get you most of what you need. There are a few variations on bore size as well. but, the stroke will give you a pretty good idea what you have.
Old Jan 7, 2005 | 09:30 AM
Mike G's Avatar
Mike G
If your new toy is a 4x4, then you can pretty much be safe that it's a 360, that's what went into the 4x's... No external markings will tell you what's inside, the stroke of the crank is the key and chances are you will have either the 3.5 or the 3.75. If you come up with something different let us know, your only other chance answer would be 3.984 and that would be a 410 or 428.
--Mike
tewkes
Feb 18, 2009 06:38 PM
Jate
Colorado Chapter
Oct 12, 2008 09:47 AM
FordManStan
Jan 3, 2006 06:25 AM
4starcstms
Dec 25, 2003 03:47 PM
SFC DAVIS
29
Oct 12, 2003 10:44 PM
