I just ran a test with my Superchip tuner and came up with a code:P0344 Which is "Camshaft Pos Sens Circ Interm. (bank1/1 Sens)". Does anyone have an interpretation of what this code means? Thanks in advance for your help
Souds like the cam position sensor is going out. My read the same code before it died. Do a search for cmp There is alot of info on it and real easy to swap out.
I guess I'd better order one up, so I at least have one on hand.
I did have it replaced once, a couple of years ago and haven't had any trouble since. Maybe this is an old code that was never removed after the sensor was installed....
