belt dressing
Old Dec 8, 2001 | 08:45 PM
Pmpmrderrr's Avatar
Pmpmrderrr
belt dressing
It is simple Ford is the best.
I don't know what is with that stuff but it is no good. My belts were making a litle noise in my truck so I said what the heck and I tried some prestone belt dressing. Now the squeaking is really loud and I can feel belt slipping. I don't understand why this would happen.
Has that happend to anyone else?
I have a pretty good feeling I am going to have to replace the belt.
I have a feeling I would get in trouble if I say what I really want to say.
Old Dec 8, 2001 | 10:00 PM
jlasater's Avatar
jlasater
belt dressing
I believe it's basically a deglazing compound that is supposed to cut the slick surface on belts and improve friction so they grab better. Bottom line, if you need it, the belt should just be replaced :-) Belt dressing is a bandage cure.
Old Dec 10, 2001 | 10:16 AM
jim henderson's Avatar
jim henderson
belt dressing
I have used these dressings and they are strictly short term fix, like a day or two. Eventually they belt gets so gummed up with this stuff that ist squeels worse than ever. Plus you have a gummy mess on all the pulleys. My most recent experiences have been with those flat serpentine belts. I will not use dressing again on serpentine belts.
Years ago I tried it with the older style v belts and I think it worked fine with those.
The best bet when a belt squeels is to either replace it or you might clean up all the pulleys reall clean with some non greasy solvent. You could also wipe down the belt but be sure the solvent used is compatible with the rubber in the belt. I wouldn't soak the belt in solvent by the way. I also will "clean" up the surface of the pulleys the belt runs on with some medium sand paper or a wire wheel.
Good Luck,
Jim Henderson
Old Dec 10, 2001 | 10:23 AM
jim henderson
belt dressing
Good Luck,
Jim Henderson
jim henderson
belt dressing
Good Luck,
Jim Henderson
Old Dec 10, 2001 | 10:29 AM
jim henderson
belt dressing
OOOOOps, sorry, for some reason the webpage was telling me I had errors sending so....
Old Dec 10, 2001 | 11:43 PM
julie 54's Avatar
julie 54
belt dressing
belt dressing is for v-belts only not serpentine belts they make serpentine pulleys to slimmey and the sepentine belt will slip worse(
Old Dec 11, 2001 | 01:35 PM
Pmpmrderrr's Avatar
Pmpmrderrr
belt dressing
I forgot to say on the bottel it said,
"will not grime up pullys or belt. This formula is specificly for restoring your belt to closest to new as it can be."
errr
Oh well belts are cheap I wil replace it this weekend.
Old Jan 17, 2002 | 06:47 AM
TallPaul's Avatar
TallPaul
belt dressing
Old Jan 18, 2002 | 08:42 AM
chief3mfc's Avatar
chief3mfc
Post belt dressing
Here's a trick I learned from a wholesale car dealer buddy of mine.
NAPA auto parts sells a silicone grease called Silglyde (sp?). I put a SMALL dab (about the size of OO buckshot) on each side of the belt. Makes it as quiet as a mouse and the belt dosen't slip a bit. Been doing it for years with no problems whatsoever
Cliff
P.S. Make sure the engine isn't running when you do this, or we'll have to call you stubby
cjben
May 14, 2013 09:55 PM
Greywolf
Apr 12, 2012 12:44 AM
jake00
Jul 6, 2007 09:19 AM
vancouverpower
25
Dec 1, 2005 09:26 AM
Greywolf
26
Jul 15, 2005 12:46 AM
