Sponsored by: Real Truck
5th Wheel Hitch Mounting
Old May 28, 2006 | 06:47 AM
captchas's Avatar
captchas
Guest
Originally Posted by PeteC
But would the hitch be located properly when using those holes? The pin should be just ahead of the axle, 2-4 inches according to Reese.
Also, the bed may have a channel that raises the bed off the frame that may not be strong enough to take the load of the 5th wheel. You really need thick (1/4" +) steel brackets between the frame and bed to which you attach the hitch.
a number 10 on a metric bolt is the metric hardness number not thread size. that standard is way different then what most of us know so well including me 42 years useing it as a mechanic on german made garbage. i still have problems. size wise a 8mm is about 5/16 a 10 is between 3/8 and 7/16 11 is about 7/16 12 is another betwwen size ,13 is just bigger then 1/2, 14 is close to 9/16. hardness the higher the number the harder and my brain can't remember just how high is the hardest made right now . we also need to watch the threads as there is a std metric and a iso metric. std is what we and across the pond use while many threads from the far east are iso which is a finer thread then a std metric fine. behond this i'm just to old to have any brains left after all the co in the shops air over the years .
as to my 5er hitch i too let the local reese hitch guy do mine and as he is also the local rhino dealer i had him spray my bed at the same time. when they got done masking it all out and doing the job it looks grand and when asked about removeing and hideing. i got no problem they will never know where it was the holes be be sprayed over after we plug them .
freightlinerfordlove
Mar 17, 2017 08:50 AM
17F250
Oct 5, 2016 09:52 PM
miklav
Jun 10, 2016 09:42 PM
jackoney
15
Jan 8, 2013 02:17 PM
Harold Graham
Jul 24, 2010 04:59 PM
