Gravity Feed Kit Throws Off Computer???
Old Oct 5, 2016 | 03:45 PM
17F250's Avatar
17F250
Any of you that have an auxiliary fuel tank and use the gravity kit by RDS... does the 2017 model throw a code if you leave the cutoff valve from the tank turned on all the time? I just got mine installed and will know myself in a few days but just wondered if I needed to be turning the valve off after it fills up for a while or for convenience I could just leave it on all the time like on my 2012 F250 without it causing the computer to go bonkers. It worked fine on that truck that had the digital miles to E but a regular fuel gauge. Every once in a while my miles to E display would just recalculate and show an increased number of miles. The only trouble with this is that occasionally the factory tank would leak a small amount of fuel out of the top vent from it staying full all of the time and would make a greasy mess of the frame when dirt stuck to it. Since the 2017's no longer show the gallons used I figure it may work fine with the valve on all of the time. Wouldn't be hard to shut the valve off every time, just wondered if anyone had any experience on the new model to know how the truck responds.
Old Oct 5, 2016 | 05:02 PM
paulstravels's Avatar
paulstravels
I am not an expert in this area by any means, but I was told that gravity feed tanks will not work with the Super Duty. Ford changed to a closed fuel system in 2015 and since then gravity feed tanks will not work. Titan makes a tank with a pump that will work. RDS may also just never checked.
Old Oct 5, 2016 | 05:17 PM
BigStu59's Avatar
BigStu59
Transfer flow also makes a pump system. They cost more but for me it will be worth it. I currently have a 50 gal transfer Flow tank on my 2004 F250 and it works great. Never had a problem with it except to change out an O-ring on top of the tank where it has a closed vent.
Old Oct 5, 2016 | 05:39 PM
Bigdon68's Avatar
Bigdon68
Aluminum Tank & Tank Accessories, Inc. does as well
Check out their tanks Aluminum Auxiliary Truck Diesel fuel tanks - Aluminum Tanks and Tank Accessories
They make the Freedon Fill system which is with a pump. I have used their tanks for over 8 years and they are great. Will be putting a 45 gallon under rolltop cover in my F450 this winter.
bigdon68
Old Oct 5, 2016 | 07:01 PM
invstr55's Avatar
invstr55
My RDS with gravity feed does not throw any codes and the valve remains open.... the computer does try to show usage but will recycle and got back to max miles to empty..
Old Oct 5, 2016 | 07:33 PM
17F250's Avatar
17F250
Thanks….I have had no issues with the RDS gravity feed not working fine on this Super Duty just like previous models so I dont know anything about the closed fuel system. It is definitely more cumbersome to install than previous models because you dont have much room and you have to remove and cut out roughly 3-4" of your 1.5" filler neck which is all metal now rather than rubber in order to replace it with the aluminum adapter that has the overflow check valve in it. Ive currently just been turning the tank valve on at night and letting it fill and then turning it off the next morning. It always seems to fill up fine without overflowing or problems. I was just wondering about the computer but invstr55 answered my question. Might try an electric pump in the future but have been satisfied with the RDS gravity feed kit since around 2005 and have had it on several trucks. Thanks everyone
Old Oct 5, 2016 | 09:52 PM
invstr55's Avatar
invstr55
My gravity feed has been plumbed into the overflow line rather than cutting the metal filler. Works great.
Chris Popanz
Aug 13, 2020 07:22 PM
dawgfan74
Apr 11, 2015 11:00 PM
epdukes13
Aug 19, 2014 09:21 AM
djfins
Mar 29, 2014 05:05 PM
gkl273
Jan 16, 2006 07:24 AM
