Tach Wire Colour?
Old Jan 6, 2005 | 01:40 AM
Mopey's Avatar
Mopey
Tach Wire Colour?
Hey Guy's , Installing a magnum remote starter on my 01 PSD. Having some trouble getting the tach mode to work. Does anyone know what colour the tach wire under the dash is and where I might be able to tap into it?
Thanks Alot, Pat.
Old Jan 6, 2005 | 12:15 PM
JMorton's Avatar
JMorton
You need to tap into the wiring at the CMP sensor to get an rpm signal.
Old Jan 6, 2005 | 12:42 PM
JNygard's Avatar
JNygard
I'm not sure about the 2001, but the 2002 has a customer access wire next to the emergency brake, green with white stripe. Its a (CTO) clean tach output. Thats what I used for my remote start.
Old Jan 6, 2005 | 02:40 PM
444dieselrod's Avatar
444dieselrod
is this just for the older body styles or is there a wire under the dash like JNygard said.
I have a 97 and a 93 and was wonder the same wher can I get a tach signal, just the CPS or is there a wire under the dash.
Diesel Rod
Old Jan 6, 2005 | 04:35 PM
yellow73bb's Avatar
yellow73bb
On the 2001, the tach wire is white with red stripe. It's not in the wires that go into the steering column (there is a white with red stripe there too, but it isn't the tach). There's another harness up in there that goes to the instrument cluster, and it's in there.
Old Jan 6, 2005 | 06:48 PM
wolfmanagh's Avatar
wolfmanagh
bulldogsecurity has this info on there web site.
I went to the main harness on the firewall. And I pretty much destroyed the cute black plastice cover on it. But a little tape and it dose not bother me.
http://bulldogsecurity.com/New%20Wir...rduty99-01.htm
Old Jan 7, 2005 | 12:30 AM
Mopey's Avatar
Mopey
I found it, same spot as wolfmanagh. White with pink stripe in the main bundle that comes thru firewall. Thanks for the help!
Old Jan 7, 2005 | 02:22 AM
Mopey's Avatar
Mopey
Thumbs up
Found it. White with pink stripe comes thru firewall in main wire bundle behind and left of brake pedal. Thanks for Help.
390428cjt
18
May 27, 2026 01:34 AM
Handegard
Feb 22, 2014 11:27 AM
satboz
Aug 18, 2011 01:53 PM
scottscott
Apr 22, 2010 04:08 PM
charles jones
Jan 7, 2006 07:59 PM
