94 PS 4WD 5sp speedometer started shutting off about a year ago every now and then. If cruise cont. was on it would fall off also. Recently the speedometer quit totally. Have check plug in behind panel and it is good. Checked fuses I think and all appear to be good. Sure appears like a connection loose somewhere. Help! Where to look or what to do.
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE
We are happy to have you on board!~
On top of the read differential there is a small device called a VSS (Variable Speed Sensor). It feeds the speedo. About a $20 part at Ford (Autozone and the like have it for around $40).
Good luck
Mike
Hi MJWHIP,
Read your comment on the non working speedo and wondered if this rear end switch that feeds the speedo would account for a non working speedo but a functioning odometer and trip? My odometer works but the speedo quit dead. I have a '99 Ford one ton chassis on a motorhome and have the rear end switch but also have a similar switch on the driver side of the transmission..which one feeds what...thanks for any input.........
