doesn't make sense
Old Dec 10, 2002 | 09:11 PM
88grandmarquis's Avatar
88grandmarquis
doesn't make sense
[updated:LAST EDITED ON 10-Dec-02 AT 10:34 PM (EST)]2 things bothering me.
1. i took the truck out today and when i got it out of the garage i discovered an oily residue covering the outside of both front tires and rims. there is no oil leaking from the motor. i thought i might have driven through something, but those are the ONLY places that this residue is. it's not even on the back tires and it has been really dry around here for weeks.
2. brakes. if i hit the brakes hard enough to lock them up, only the front pass. side tire locks most of the time. seems to do it more when cold. wondering what could be done to get more braking to the rear wheels or if something is not working properly.
truck is below.
Old Dec 10, 2002 | 09:57 PM
desperado_18_2000's Avatar
desperado_18_2000
doesn't make sense
Your proportioning valve may be sticking, or gumming up if the fluid is contaminated. i had my old lincoln do this if i didn't drive it for a few days.
i don't have clue as to where that residue could have came from on your tires.
Old Dec 10, 2002 | 10:17 PM
steve83's Avatar
steve83
doesn't make sense
Front brakes sounds like a bad/loose wheel bearing up front and sticking autoadjusters out back.
Residue - no idea. Is it really a problem?
Old Dec 10, 2002 | 10:24 PM
wildjon300ci's Avatar
wildjon300ci
doesn't make sense
Could be wheel bearing grease (the residue). I don't really know what could be causing one wheel nt to lock up.
Old Dec 10, 2002 | 10:26 PM
Ford_Six's Avatar
Ford_Six
doesn't make sense
I'd have to say wheel grease on the tires, and do you have rear wheel anti-lock? Could also need to have the rear brakes adjusted, or frozen wheel cylinders, or a dozen other things. Take the drums off, and have a look.
Jared
Old Dec 10, 2002 | 10:36 PM
88grandmarquis
doesn't make sense
thanks for the advice so far. the residue isn't really a problem, just has me wondering.
Old Dec 11, 2002 | 06:11 AM
Jimbare's Avatar
Jimbare
all alone in the world
doesn't make sense
check your calipers, if they have phenolic pistons replace them. they may be stuck-sticking. it does sound like wheelbearing grease on the rotors.
Old Dec 11, 2002 | 07:24 AM
Jens's Avatar
Jens
doesn't make sense
