Block Coolant Drain Plug Installation
Old Jan 4, 2005 | 02:26 PM
jasond5150's Avatar
jasond5150
Question Block Coolant Drain Plug Installation
When I install a new coolant drain plug on my block do I need to use any sealer like pipe-dope or teflon tape on the plug?
Old Jan 4, 2005 | 03:58 PM
Ultramagdan's Avatar
Ultramagdan
I don't think so. There pressed in anyway, so it would be hard to stick something on 'em.
Old Jan 11, 2005 | 03:59 AM
Ed's Avatar
Ed
Years ago, I had a 1969 Dodge Dart GTS with the 340 4-BBl. I had more fun than humans should be allowed to have. I maintained the Dodge, and had replaced the block plugs with brass pet***** to drain the coolant, out of the block. I used a small amouth of white teflon tape around the threads. It never leaked, and flushing the block was very easy this way.
Old Jan 12, 2005 | 08:04 PM
kotzy's Avatar
kotzy
They are pipe threads and are tapered, and teflon tape or pipe-dop work very well.
You can get them to seal if you can get them tight enough with out it---- dope or
tape lubricates the threads so you can.
Deluxe06
Apr 11, 2014 12:13 PM
Avanti
Escape & Escape Hybrid
Jul 16, 2013 01:37 PM
F250racer
Apr 24, 2009 08:41 PM
ngng
Mar 19, 2009 09:22 AM
steuben
Nov 8, 2008 01:20 AM
