Thermostat housing!!!! HELP....keeps cracking....HELP
Old Nov 18, 2002 | 06:41 PM
sbishop's Avatar
sbishop
Post Thermostat housing!!!! HELP....keeps cracking....HELP
Hi, I have just put on my second thermostat housing last weekend and I just notice it's crack on the bottem by the bolt....and yes it's leaking again...what i'm I doing wrong? I tighten the last one to 18 lbs is this too much???
1984 F-150 300/4spd
Thanks for any help!
Old Nov 18, 2002 | 07:24 PM
Franklin2's Avatar
Franklin2
What I have found that gives me housing problems:
Surfaces not clean enough
Gasket too thick or more than one used at a time.
Thermostat falls down out of the cavity a little and gets caught under the gasket when you tighten it down.
Old Nov 18, 2002 | 08:04 PM
sbishop's Avatar
sbishop
I have cleaned the housing...going to pick up a new gasket tomorrow..will make sure the thermostat is in the correct position...how much should I torque the bolts???
Old Nov 18, 2002 | 08:19 PM
cdd5599's Avatar
cdd5599
Are you placing the thermostat on the block first or in the housing. You should be placing it in the housing then push assembly against block. It should only be snug very little torque.
Chuck,
Old Nov 18, 2002 | 09:45 PM
84f150's Avatar
84f150
Are you using an OEM housing or one of those aftermarket SPECTRE pieces of junk?
Also make sure you are installing the Thermostat in the housing, then the gasket over it, then bolt it to the block. Snug one bolt, snug the other, then tighten em' both. Not to much torque.
Old Nov 19, 2002 | 04:15 AM
sbishop's Avatar
sbishop
was putting the gasket then the thermostat into the block, will try putting in the housing first, Thanks!
Old Nov 19, 2002 | 07:05 AM
cdd5599's Avatar
cdd5599
I did the same thing the first time. what happened was the thermostat didn't get centered in the groove and you were forcing it between the edge of housing and block .
Chuck
Old Nov 19, 2002 | 11:59 AM
HotWhlz85's Avatar
HotWhlz85
Been there, done that. What happens (like another poster said) usually is the thermostat slips just a bit and the edge gets between the housing and the block. When you tighten the bolts on the housing down on the uneven surface you'll crack it every time. I have started using yellow weatherstripping adhesive to hold the stat in place. Place your stat in the housing, then a just a little dab of the adhesive on the flat part of the housing (doesn't take hardly any at all to work), then place the gasket on. Let it set up for a few minutes and install. I have never cracked a housing since doing it this way.
Ron
Old Nov 19, 2002 | 12:22 PM
84f150's Avatar
84f150
I just use a little silicone that is made for water pumps, works like a charm.
Old Nov 19, 2002 | 12:31 PM
sbishop's Avatar
sbishop
thank you all for the reply's...will be changing it tonight!!!
Old Nov 19, 2002 | 02:11 PM
Franklin2's Avatar
Franklin2
Old Nov 19, 2002 | 06:02 PM
impguy56's Avatar
impguy56
if you go to napa they sell a gasket that has one side with adhesive on it just put the stat in the houseing apply sticky side to houseing over therm and bolt her on, that way you dont have to worry about getting it lined up or slipping when you start tightening
Old Nov 20, 2002 | 01:48 PM
Ford_Six's Avatar
Ford_Six
I always put two dabs of black RTV on the t-stat 180* apart, press it into the housing firmly, and let it cure. Then, I use the import gray RTV, or Mopar ATF RTV, instead of a gasket to install the housing. I have yet to have one leak, but the key is to not use too much. Remember, however much oozes out outside, is just the same on the inside.
Jared
Old Dec 14, 2002 | 11:55 AM
1313's Avatar
1313
hey file down the housing untill it's flush / flat.do the same with block.it will be ok.
dwayne
kyle j
Jan 2, 2025 10:50 AM
Frdtrkrul
Oct 30, 2017 12:10 AM
ofwgkta_alonzo
1978 - 1996 Big Bronco
May 16, 2017 11:36 PM
super66
19
Apr 28, 2017 06:08 PM
cutlass
51
Jun 16, 2011 12:54 PM
