89 Bronco - code 18 - HELP!!
Old Jan 3, 2005 | 09:13 PM
msautry's Avatar
msautry
It's an 89 Bronco, 351 motor, C-6 transmission, and my daily driver back to work and such.
Tracked down what originally seemed to be just a fuel pump/relay problem. Replaced those and it was good to go.
Unfortunately, doesn't seem to be the extent of the problem. Bronco will sometimes start-run for a few miles. Go run an errand and come back out and
it just cranks. Wait an hour or so, it'll start and run for a few miles. Got it home today, check the low voltage on the coil, coil wire resistance, primary cicuit voltage, etc..... no luck.
Pulled the codes and got the 18 - open spout circuit.
Time to replace the module in the distributor??
Any help/ideas/places to start looking?
Thanks to any and all that can help -
msautry
Old Jan 3, 2005 | 10:59 PM
Franklin2's Avatar
Franklin2
Sounds heat related, so it could be the module. You might want to check the wiring going to the module too. When it cools off, it starts, so it sure does sound like the module.
Old Jan 4, 2005 | 09:22 PM
msautry's Avatar
msautry
Engine code 18 - revisited
Went out this morning - bronco started right up. I think your right as re:
the problem being heat related (it was about 25 degrees here last night).
Looks like I'll be pulling the distributor this weekend and replacing the
module and the stator along with the cap and rotor (I mean, as long as
I've got it all out....).
I'll check the codes after it's all back together and see what's what...
Thanks
msautry
Old Jan 7, 2005 | 03:58 PM
Beast12's Avatar
Beast12
I have had a code 18 on my 85 F150 (5.0 EFI) for the last year. No problems but it bugs me (and yes I have reset the codes).
-Matt
drake_bartel
1978 - 1996 Big Bronco
Nov 23, 2016 11:16 PM
freevan
Nov 5, 2016 10:32 PM
msautry
Feb 3, 2005 10:35 AM
msautry
Nov 18, 2003 12:08 PM
msautry
Oct 15, 2002 10:51 AM
