radius arm bushing failure
Old Jan 3, 2005 | 08:16 AM
raazrbks's Avatar
raazrbks
Question radius arm bushing failure
My 1996 F150 5.0L supercab radius arm bushings have been replaced twice. The truck has 70,000 miles on it. The last time, they lasted about 100 miles & literally fell out? I have had two so-called mechanics look at it but no luck finding the root problem. Any suggestions?
Old Jan 5, 2005 | 12:23 AM
DARK_HORSE's Avatar
DARK_HORSE
The bushings that you used. Were they polyurethane? I have a set on order right now for my 92 F-150 from Jeffs Bronco graveyard. I'll let you know how they look. Make sure yours are torqued properly. There is also a white plastic bushing inside them. Make sure that is good. Another thing make sure your axle pivot bushings are good bacause they could cause extra slop in there. My truck has the original ones in there and there pretty worn out. It makes a clunk when I back up and then go forward. It also has 4 inches of lift and 33's so that's not helping.
Old Jan 5, 2005 | 07:01 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE
We are happy to have you on board!~
Old Jan 5, 2005 | 10:36 AM
hladun's Avatar
hladun
The "radius arm bushing" is actually several pieces including the core that Dark_horse mentions. I suspect you didn't have them all. Check with a dealer.
Old Jan 5, 2005 | 10:41 AM
raazrbks's Avatar
raazrbks
Thumbs up
Thanks to the both of you on the input. I actually paid a so-called mechanic to purchase & install. Will have to get with him regarding what was actuallly purchased from the parts house...
Old Jan 10, 2005 | 01:32 AM
DARK_HORSE's Avatar
DARK_HORSE
I just changed mine out this weekend with Daystar polyurethane bushings. They seem to be a lot better than factory rubber bushings. Good luck with yours!
kbak
Dec 21, 2006 06:03 AM
fatdaddy
Jun 29, 2002 08:14 PM
Mexray
1978 - 1996 Big Bronco
Apr 6, 2002 04:47 PM
phaffy12
Feb 18, 2002 06:13 PM
