Speedometer correction?
Old Jan 2, 2005 | 01:20 PM
thesprocket26's Avatar
thesprocket26
Is there a part you can add to your speedometer cable to display the correct (or as close to it as possible) mph speed with tire and gear modifications?
Old Jan 5, 2005 | 06:18 PM
midlf's Avatar
midlf
Years ago when two speed differentials and after trans overdrive units were more popular there was a device to install in the speedo cable that was 1:1 ratio and could shift to a 1:"to whatever was needed" ratio so the speedo would work correctly. It was an electrically or vacuum shifted device depending on how the OD or Diff was actuated.
Check with a speedo shop or a large truck shop to see if such a device is still available. You get the needed gear ratio put in it and always leave it "shifted" to the alternate ratio.
Vin Man
Apr 24, 2012 05:29 PM
Steves55
Oct 27, 2010 03:43 AM
TERSEJR
Computer Chips & Tuners
Sep 30, 2008 07:03 PM
68FE390
22
Oct 13, 2007 01:21 PM
AzBaddBoy
Jun 9, 2006 01:23 PM
