Computer Chips & Tuners
speedometer correction
Old Sep 20, 2003 | 10:35 AM
TERSEJR's Avatar
TERSEJR
I have a 2000 F350. 7.3. 6 inch lift, 3.73 gears and automatic ,with 37 swamper ssr's. Has any body tried Super Lift's True Speed yet ? It's supposed to correct the milage and speedometer.
Old Sep 22, 2003 | 11:57 PM
FTE Ken's Avatar
FTE Ken
Yes, the Tru Speed will work. It handles just about every computer controlled vehicle out there and will correct for gear ratio changes and tire size changes in less than 1/2 inch increments. I highly recommend the product.
Old Sep 22, 2003 | 11:58 PM
TERSEJR's Avatar
TERSEJR
thanks alot I'll have to get one.
Old Sep 23, 2003 | 01:13 PM
CEP's Avatar
CEP
You may want to look into Atrol's electronic ratio adapter (ERA). It's simular to the TrueSpeed and @ $125.00 it costs a little less.
This unit uses DIP sw to dial in the speed ratio vs. the POT's that TrueSpeed uses.
I'm very statisfied with the unit I have.
The web site is "http://www.atrol.com/" look for "ERA".
- Good luck.
Old Sep 23, 2003 | 04:26 PM
TERSEJR's Avatar
TERSEJR
thanks I will look it up .
Old Sep 26, 2003 | 11:31 AM
cruisen's Avatar
cruisen
I have not used it personally but, I have heard good things about it. Given a more or less 1-2 mph correction rate. I just had to reprogram the PSOM on my speedometer.
You might want to give Your Local Ford Dealer, Just to see if they will do it or if your truck has that option before you go spending the 200 or so Bux that it cost.
Good Luck.........
Old Sep 26, 2003 | 02:11 PM
TERSEJR's Avatar
TERSEJR
Thanks.....That a good idea. I will also consider that as well.
Old Sep 26, 2003 | 10:18 PM
cruisen's Avatar
cruisen
No problema, glad to help out when I can.......
Old Sep 30, 2008 | 07:03 PM
Mercury45's Avatar
Mercury45
theres a few devices out there... i personally use a merlin controls speed wizard and it is great - easy to install and it is the only one that provides a user interface.
no dip switches to move or pots to turn just two switches up and down and it used your speedometer itself to set the correction.
they all do their job though, its just how easy to do it.
kenny
1950FordF1
Oct 25, 2016 08:49 PM
David8949
Jul 21, 2016 10:41 AM
klr650goldwing
May 23, 2016 10:41 AM
Guhfluh
Aug 31, 2013 06:01 PM
Vin Man
Apr 24, 2012 05:29 PM
