You change the speedo gear in the side of the tranny. Follow the cable to the tranny, remove small retaining nut and pull it out. Take note of the gear tooth slant and count them. It is important to try to find out how much it is off before trying to correct it.
Report your tooth count, slant, and how far it's off and we will try to help you correct the issue.
Your welcome
To count the gear teeth you will need to have the truck jacked up and turn the wheel and count the end of each tooth. Or take a chance on the count being 9, i have three c6 trans and they each have 9 teeth machined into the output shaft.
Your welcome
not understanding what wheel you are talking about turning.
thats a great calculator yall posted but how do you know how many revolutions the speedo makes in a mile?
It already there 1000 or look here,your right different size tire would change that number. Sorry that is for tire revolutions, the the artical above the calculator says 1000 is good starting point for speedo.
Well i don't think they make to many options for the drive gear, some drive gears are mechined into the rear main shaft of the trans.
The calculator does give you the option to find either one so i would say yes if the drive gear is removable, but i am not 100% on that.
