Ok Got The Brake Light Problem Fixed!!
Old Jan 2, 2005 | 12:50 PM
barebackjake's Avatar
barebackjake
it was the fact that there wasnt engough resistave load on the brake light circuit. LED's are a inductive load, added some incandescants on the circuit and its good to go. next issue if you have seen the pics of the bed i have reds and ambers back there. i want the reds as brake only and the ambers to be my flashers. i could use the high mount brake light for my brake and add the resistor packs that the LED light manufacturer makes on the existing stop/turn wires so i dont go back to the problem i had before. Then run the turn signals off of the fronts im pretty sure the flasher module would be able to handle 2 leds on each side coming from the front. im going to fit the oval LED's in the front lights and some 2.5 round LED's in the corner running/flashers. I like how fast the LED's come on and off instrad of the somewhat delayed incandescants. Im hoping my ABS light problem will be remidied now havent driven it yet....
Old Jan 2, 2005 | 12:56 PM
realhp's Avatar
realhp
I think you should be fine hooking up your lights to the front turn signal curcuit.
Luke76
87
Nov 1, 2021 08:10 PM
cj85f150
Apr 24, 2015 07:08 PM
rescue947
1983 - 2012 Ranger & B-Series
15
Mar 16, 2013 06:34 AM
sunuvabug
Electrical Systems/Wiring
Aug 14, 2007 07:47 PM
