LED tailgate light strip wiring
Old Jul 30, 2012 | 09:12 PM
cj85f150's Avatar
cj85f150
So i have an 85 f150 and i bought a 3 color light strip to put on it. I have installed it and spliced it into the according wires. it is grounded and has a constand 12v feed as it was told to do in the instructions. But when i tested it everything works like the brake light, running light, revers light, and the blinkers work. The problem is when the blinkers are one either the left or right one it will flash the amber LED but then start to flash the red brake LED and then go back to flashing the ambers again.
So my question is did i happen to splice the blinkers into the wrong wires?
P.S. I did replace the flasher in the fuse box to be able to work with LED blinkers and tail lights.
Old Jul 30, 2012 | 09:19 PM
Diesel_Brad's Avatar
Diesel_Brad
Sounds like the LED strip is a POS
Old Jul 30, 2012 | 10:20 PM
ctubutis's Avatar
ctubutis
What wires did you splice into? What are their colors?
Old Jul 31, 2012 | 06:38 AM
truckertrav's Avatar
truckertrav
If your lights all work, as you mentioned, then your wires are connected correctly.
If you have the original turn signal/brake lights still on the truck you can get a feed back to your led strip.
You shouldn't need the led flasher.
The strip thinks that you are hitting the brakes when the turn signals come on. That is probably why the brake lights flash after the turn signal is activated for a few seconds.
I hope I didn't mislead you but LEDs have to be connected with + and - voltage correctly.
Other than that, double check the paperwork with the strip for exceptions,applications,etc.. Hope this helps..Trav.
Old Jul 31, 2012 | 08:28 AM
80FlareSide's Avatar
80FlareSide
In trucks without a 3rd brake light the stop and turn lights are one in the same.
Brake Switch - Powers Left and Right
Left Turn Signal - Powers Left, but through flasher
Right Turn Signal - Powers Right, but through flasher
Now, when you are braking and turning, the turn signal switch actually uses the flasher to interrupt the left or right, leaving one light on and one flashing. What you are seeing is the result of the wiring in your truck doing exactly what it was designed to do.
The only solution I can think of is to return the strip with the separate amber turn signal, and get something that uses the same lights for stop and turn.
Old Jul 31, 2012 | 09:47 AM
JayzDaddy's Avatar
JayzDaddy
Thats got to be one of the most obvious things that i would have NEVER thought of myself 80FlareSide. Great post IMO.
Old Jul 31, 2012 | 09:12 PM
cj85f150's Avatar
cj85f150
the wires i spliced into were a bright green and a bright orange for the left and right blinkers
Old Apr 24, 2015 | 07:08 PM
gtanns's Avatar
gtanns
80FlareSide..!
I've been trying to figure this out as well.
My 1980 is as you describe, with the turn signal and brake light being the same...
...you can see in my profile picture, the lights on the tailgate that I want to light up when the I hit the brakes/reverse...
I don't want my tailgate lights to flicker when I use my turn signals.
I was confused because at the back of my truck, there are only three wires.
I assume:
1 is for the left indicator/brake
2 is for the right indicator/brake
3 is for the rear taillights
PLEASE CORRECT ME IF I'M WRONG!
I assume the brake wire is spliced into each wire for the indicators...
Should I trace the indicator wires to where they connect to the brake wire, and then solder my tailgate light into the single brake wire??
pat420swed
Jan 10, 2016 09:48 PM
cherrybomb37
Oct 8, 2014 10:16 PM
jreilly57
Nov 11, 2013 08:03 AM
furyus
Oct 20, 2009 12:07 AM
Bronco2guy
Bronco II
15
Mar 25, 2003 07:02 PM
