Need to remove the **** to access behind the panel.Requires a small hook tool(Hayne's Manual)to depress the spring holding it on.Anyone know the diameter of the tool and how much of a bend?
I'll make something up.
I've always used a small flat blade screwdriver to depress the retainer. When you rotate your **** you will see a notch out of the back of the **** put the blade of your screw driver in the notch and pull the the screwdriver toward yourself and the **** should pull off.
similar topic...where can i get a new **** shaft?...my **** doesn't stay on any more...looks like the metal is worn down too much for it to hold tight. Part numbers?
Thanks guys.
Will try 'em all till I get it off.
9599,when the **** busted on the wipers,I made a **** out of aluminun hex with (2) 4-40 set screws to hold it on.
mini flat head will get the job done.. First time i had to get that off i decided to use a coat hanger, so i had this hugh long wire for this little project.. haha almost poked my eye out cause the end of the hanger was swinging everywhere..
Thanks guys.
Thanks for the idea suds but, i'd like to keep my stock **** and just want a new shaft. Anyone know the part number?
