just signed in as new user. this may have been addressed in the past. in the past 4 years i have had 2 smoke fires from leaves in the blower, coil area where the heating element is. how do they get in there and how do i prevent it? it's a 86 f150 when this happens my truck looks like an old cheech and chong movie with all the smoke coming out the windows!!!!!!! thanks
They get in there through the grill in front of the windshield. They work their way in when the are green and flexible. Then they dry out later on and cause the trouble. The panel with the grill will come completely off if you take the wiper arms off. You could then mount a fine mesh screen under the opening if you wanted.
I have had this happen to me once before and about the only way to prevent the fires if you are under alot of trees is to clean out the heater coil area every so often to make sure there are no leaves in it.The mesh would probably work too. Never tried it.
You can swap to an '87-91 wiper valance that has pinholes instead of slots (the '92-97 doesn't fit the hood :-( ), but a few leaves can still get in under the windshield trim. Pull the blower motor & the resistor plate - if you can't get them ALL out, pull the evaporator core by removing the plastic cover that faces the R exhaust manifold.
Yep, had that done when I got the 86 repainted. Perfect fit, no more leaves. I never had a problem with them burning, they'd just blow out of the defrost or the side kick panel vents every time I'd open them.
