E350 Blower motor not working
Old Dec 30, 2004 | 08:18 PM
Tinker52's Avatar
Tinker52
Hello, what a great site! We have a 94 E350 that the blower motor quit on, so we found all the wiring diagrams we could muster, and checked the fuses all checked out OK, I see the fan switch gos through resisters to ground,we put a hot wire on + side of blower it worked great, can anyone tell us if thier is a blower relay,or fuseable link that might be open as we cant tell where power gos to, Dealer was no help just said bring it in with a pile of money, Thanks tinker52
Last edited by Tinker52; Dec 30, 2004 at 08:23 PM. Reason: new and not up to speed, bad title
Old Dec 30, 2004 | 09:12 PM
Racerguy's Avatar
Racerguy
Hi Tinker and welcome to the forum
I don't have a 94 manual here but I looked at a 96 (I think it's close enough) and it shows a blower motor relay under the hood in the front driver's side. It should have a Yellow wire to it that is hot at all times from a fuse in the underhood fuse box. Power goes out from the relay on the Orange with Red wire. The black wire to the relay is ground. The Yellow with Red wire comes from the function selector switch to turn the relay on.
Old Dec 31, 2004 | 03:57 PM
Tinker52's Avatar
Tinker52
Thanks Racerguy now I know what to look for, I wont be able to get to it until monday, keep you posted, Thanks Bob Tinker52
Old Dec 31, 2004 | 05:13 PM
triton_2002's Avatar
triton_2002
Let us know how it turned out. My dad's E350 also has the same problem.
Old Jan 2, 2005 | 06:12 PM
Tinker52's Avatar
Tinker52
Hello, Racerguy you were right on the money. we pulled the battery out and found 2 relays side by side, the one with color codes like you said was bad, went to Shucks and got a new one, works great, The power of the Internet Rules! Thanks again tinker52
Old Jan 2, 2005 | 06:24 PM
Racerguy's Avatar
Racerguy
Good to hear that you got it fixed
Old Sep 28, 2018 | 01:36 PM
WarrensE350's Avatar
WarrensE350
Hello, I apologize for raising an old thread but I figured it was better than starting a new one for a related question.
My 96 E350 has front and rear blowers, and neither is working... Do they both go through that same blower motor relay?
Old Sep 29, 2018 | 10:21 AM
projectSHO89's Avatar
projectSHO89
No, they have individual relays.
Check fuse F9 under the dash and verify it is passing power while the ignition switch is in RUN. It goes to your MODE switch and is supposed to pass power to energize both relays when the switch is in any position except OFF.
Old Sep 29, 2018 | 10:52 AM
WarrensE350
Great, thanks! Appreciate it, neighbor. (Foristell here).
Old Oct 2, 2018 | 09:24 AM
WarrensE350
So in case this helps someone someday, my issue wasn't the fuse or relays, or anything in the wiring for that matter. Turns out, the A/C Heater Control (my part number E1AH-190961-BA) managed to come apart. I guess that makes it behave electrically as if the entire unit is in the Off position, where nothing works. I cleaned it up, superglued it back together, and it's all working fine again now. I guess you learn something new every day. It's the unit that is controlled by the vent selector switch and also connected to the vacuum lines, looks like this:
Anyway, back in business now. Maybe someone will have a similar issue someday and this may help.
Old Oct 2, 2018 | 11:40 AM
projectSHO89
That would be what I called out as the "MODE switch". If it wasn't passing power from F9 to the relays, then that does indeed explain why it didn't work. First time I'd heard of one of those switches coming apart at the seams!.
Old Oct 2, 2018 | 12:12 PM
WarrensE350
I seem to run into a lot of things rarely or never seen, unfortunately.
For example... I just got the dash back together. They heater/AC controls work great, smoother than I've ever seen. Probably because I cleaned everything up and put in fresh grease. Anyway...
Now the turn signals don't work, neither by the stalk or the hazard button. I can't see if the high beams are coming on, but the high beam indicator light does not illuminate on the dash either. Where would these things tie together? I didn't mess with any of that, so I'm laughing at my luck again. They worked fine yesterday, of course.
Jefftopgun
Jul 13, 2017 04:58 PM
douglas.
1997 - 2003 F150
Jan 31, 2017 08:25 AM
Texasdeereandhorse
Dec 7, 2016 05:42 PM
annaleigh
Jul 24, 2016 09:11 PM
clifjen
18
Nov 12, 2013 07:43 PM
