biggest tire size?
Old Dec 28, 2004 | 08:12 PM
thtanoyinguy's Avatar
thtanoyinguy
biggest tire size?
i am about to buy my grandpa's 1980 F-150 2x4, A/T, with the 302. i want to put some "beefy" tires and rims on it. what is the biggest tire size i can fit with altering anything? i found a 3" body lift, but i wanted to see what i could fit stock before i think about the lift. basically let me break it down what i am lookin for. i would like to be able to fit somewhere between 30's and 33's. whatch think? can i fit those stock?
Old Dec 28, 2004 | 10:09 PM
the peppermint's Avatar
the peppermint
31s would do the job. i put 33s on my 84 f150 2x4, they fit at stock height but that was as big as a person could go, it looked goofy like that until i lifted it 3 inches in the rear and 2 in the front, the width of the tires would probably be best at 10.50
Old Dec 29, 2004 | 05:59 AM
thtanoyinguy
cool...so neither the 31's or 33's rub? what do you think about thornbirds being on there? remember i am going for beefy lookin.
Old Dec 29, 2004 | 06:05 AM
Ford_Six's Avatar
Ford_Six
Well, on my 80 F-100 parts truck, I had 34x9.5 super swampers that came off a friends Bronco. They fit ok, rubbed a little on the radius arms when trying to turn tight.
Old Dec 30, 2004 | 06:07 AM
thtanoyinguy
34's ! geez!.... your truck has to be a 4x4.... i was talking about 2x4...
Old Dec 30, 2004 | 08:34 AM
Hourang's Avatar
Hourang
the 31s should fit without problems, my 1500 2wd had 31s on it and it looked like they shoulda been there stock.
Old Dec 30, 2004 | 09:39 AM
REBELboy_327's Avatar
REBELboy_327
I have an 84 F-150 2wd with 32x11.50 on it. They rub a little at full turn and when I hit a good sized bump they hit the fender.
Old Dec 30, 2004 | 04:07 PM
1980_f_100's Avatar
1980_f_100
my 80 2wd has 31 and it is rought when taking bumps and what not. they hit off the platic interfenders. kinda sucks. but it gets the job done
Old Dec 30, 2004 | 05:33 PM
thtanoyinguy
then i think 31's will be the tire size i go with...
Old Dec 30, 2004 | 11:09 PM
1980_f_100's Avatar
1980_f_100
i'm actually using bf goodwrench all terrian they look pretty mean.
Old Dec 31, 2004 | 12:31 AM
1984 f250's Avatar
1984 f250
be careful with thornbirds because they have big lugs that stick out pretty far, but there a good choice tire because they seam to last long and there safe in the rain, and there half decent in the rain.
Eric
Old Dec 31, 2004 | 08:37 AM
Boss50's Avatar
Boss50
I have 31x10.50's on the front of my F100 2wd. They look sweet except they hit my front fender when I go over a bump, I only have about 2 inches of clearance.
Old Jan 2, 2005 | 10:38 AM
Rage's Avatar
Rage
I put 32X11.50's on my 1980 F-150, they fit fine until you hit the trail. I had to put a 2 1/2 inch body lift on the truck to stop the rubbing.
Old Jan 2, 2005 | 01:25 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE we are happy to have you on board!~
Old Jan 2, 2005 | 01:58 PM
71 Sport Custom's Avatar
71 Sport Custom
My 95 has 30/9.50/15's. I've never had any hitting or fender rubbing. I bought a 2 1/2 inch suspension lift for my 87 and blew the motor before installing it. I may put it in the 95.
martinbarrio
Nov 6, 2013 07:37 PM
Powerstokelady
Jan 27, 2013 12:45 PM
Gregxlt
Jan 25, 2004 11:50 PM
goosedaddy61
1997 - 2003 F150
26
Oct 4, 2003 11:10 PM
