ignition problem
Old Dec 28, 2004 | 11:03 PM
Don Senkow's Avatar
Don Senkow
On a duraspark you can bypass the ignition switch and the resistor by running a wire to the positive of the coil. The coil+ and the module power are connected in the harness. Try checking for spark at the coil wire by turning the ignition on and then off without turning over the starter. If you get a spark every time the coil and module are OK. Also check the ground inside the dist. The black wire in the 3 terminal connector grounds the coil - thru the module. It is attached to the dist. body with a screw by the strain relief inside. If the dist is not grounding to the block you will get either no spark or poor spark. Had this happen once, was very hard to find. Try a jumper from the dist. to the battery neg....Don
Olbeater
Nov 1, 2010 05:31 PM
I8URCAT1
Nov 14, 2008 12:17 PM
g_k50
1978 - 1996 Big Bronco
21
Oct 11, 2008 07:48 PM
dcollier
Mar 13, 2006 12:28 AM
Qvan666
Oct 28, 2003 01:59 AM
