Van Dies
Old Oct 26, 2003 | 01:15 AM
Qvan666's Avatar
Qvan666
Van Dies
Help!!!
I have a 1978 ford E250 (4wd Quadravan) that has just started dieing on me. It will start right up, run for 20 or so minutes and then die. I lose my spark. I have a new coil and ignition module.
After it sits for 45-60 minutes and cools down it will start and run till something (who knows what) in the engine compartment gets hot (? just a guess) and cuts off my ignition.
Does anybody have any ideas on this one? I don't have a schematic, so I am shooting in the dark here.
Also, when hot will turn but not fire in start position, but seems to try to run as key goes to off poisition.
Engine is not overheating, no catalytic converter.
TIA
bob
Old Oct 26, 2003 | 01:23 AM
LxMan1's Avatar
LxMan1
Hi and welcome to FTE
It sounds like the pick-up coil in the distributor is dying on you. I would just buy a new (rebuilt) distributor. It's easier to change than just the pick-up coil and the new one will have tight bushings so that the shaft runs true.
Jimmy
Old Oct 26, 2003 | 03:00 AM
Qvan666's Avatar
Qvan666
Thanks lxman, that is what I was beginning to think. I had just about the same problem with a 79 F150 with a 429 and mallory dist. The pickup in the dist went and was giving me the same type symptoms.
Thanks for the welcome.
bob
Old Oct 26, 2003 | 04:51 AM
LxMan1's Avatar
LxMan1
Glad to help, le me know how it works out.
Man I love those Mallory Unilites. They were pretty dependable and very accurate.
Jimmy
Old Oct 27, 2003 | 09:41 PM
Qvan666's Avatar
Qvan666
Turned out to be the pick-up coil (stator) in the distributor.
I really need to look at getting a newer FI, electronic ignition, more gas station unfriendly motor into this thing.
It is a 78 quadravan conversion that I found in Montana, while 25 years old, it only has 80k miles on it. It just wasn't driven much. The previous owner did a great resto job on the exterior, and the interior is still very good. So, I really don't want to get rid of it just yet. Pius, it come from the age before computers.
bob
Old Oct 28, 2003 | 01:59 AM
Torque1st's Avatar
Torque1st
Posting Legend
A computer comes with EFI...
You already have electronic ignition. The std OEM electronic ignition modules can be tested at most good part stores for free.
Merlin Miller
20
Jun 2, 2014 12:03 PM
nothercrash
Feb 27, 2014 08:49 PM
cyris426
Nov 22, 2012 09:10 AM
pageparsley
Oct 9, 2005 07:41 AM
B.A.D. Bronco
1978 - 1996 Big Bronco
Jun 25, 2004 12:16 AM
