Starting fluid
Old Dec 28, 2004 | 07:04 PM
1982fordf100's Avatar
1982fordf100
Starting fluid
Is using starting fluid bad for an engine? I have had to use it a few times on my 82 F100 when it sits for a week or so without starting. I only give it a little shot down the carb for about 1 second. It starts after that. I think I heard somewhere that it can cause damage to the rings. Maybe because it burns hotter or is so flammable? I know not to use it on a EFI engine.
Old Dec 28, 2004 | 07:38 PM
opus's Avatar
opus
Starting fluid is not bad for the engine....in the hands of someone that knows how to use it. Just a whiff is all that is needed. I see people put it on like they would deodorant! I can remember going through over a case of ether a day at extreme times when I was in that line of work.
Old Dec 29, 2004 | 10:13 AM
beartracks's Avatar
beartracks
It can affect the air cleaner. Especially on an oiled one. It also can do dmage to 2 stroke engines that mix oil with the fuel. Use carefully it shouldn't be a problem.
nobody1
Mar 24, 2012 10:02 AM
soundguy567
Aug 1, 2010 07:09 PM
zman1202
39
Jul 7, 2009 10:47 AM
trvaughn
Jan 31, 2007 09:47 AM
dbuck50
Jul 11, 2006 01:30 AM
