Conversion 4x2 to 4x4
Old Dec 28, 2004 | 05:23 PM
nameth28's Avatar
nameth28
I was given a rotted out 95 f150 4x4. I have owned a '96 4x2 and always wanted to make it 4x4. Can anyone foresee any issues I might face pulling the front diff and additional components from the 95 to the 96 to make mine 4x4.
thanks
Old Dec 28, 2004 | 05:49 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…when you have a question. If you have a minute check out the Guidelines, it will help to navigate through FTE.
Enjoy FTE
Old Dec 28, 2004 | 06:36 PM
acerockola77's Avatar
acerockola77
There's an article in the tech articles about the swap, you might want to take a look at it.
Old Dec 28, 2004 | 07:46 PM
leverettq5l4's Avatar
leverettq5l4
I also have a 94 F-150 4x2 and was thinking of doing the same thing to mine. I read the tech artical and it sounds easy enough using components from a similar year truck. What I was thinking of doing was to use a T-18/NP-208 combo from an earlier truck and a solid Dana 44 from a 79 or earlier F-150. Anyone ever try it? Would there be enough clearance for a straight axle?
Thanks
L.F.
Old Dec 29, 2004 | 02:25 AM
Egor's Avatar
Egor
Thanks
L.F.
I think the pre 80 frames are narrower than the newer trucks, so you would have to re-weld the perches into the right place. I'm sure the straight axle would clear, but you would need a torch and welder.
Roger T. Pipe
Apr 3, 2014 08:32 AM
erupert66
Jun 26, 2013 02:51 PM
brobrad
1983 - 2012 Ranger & B-Series
Oct 24, 2012 01:12 AM
gotboostido
Mar 18, 2007 06:43 PM
jkiser96
Jan 9, 2001 07:05 AM
