2-Piece Front End vs. Solid Axle
Old Mar 31, 2014 | 01:06 PM
Roger T. Pipe's Avatar
Roger T. Pipe
I have a guy about an hour away who has a heavy-duty front end from a '95 250. I'm looking at a complete front-end rebuild on my 96 this Spring and was wondering if it is worth swapping out parts from this truck. What is the difference between the 2? My 96 is >8600 and has the 2-piece front end. Everyone I talk to says the solid axle is better. True or not? Bolt in or do I have to do mods? My truck is a 96 4x4 250 5.8 E4OD. The one upstate is a 95 250 4x4 with (I think 460) Any help or input would certainly be appreciated!
Roger
Old Mar 31, 2014 | 02:55 PM
Jarryd's Avatar
Jarryd
F250 is still a ttb axle and isn't much stronger than your stock setup.
Old Mar 31, 2014 | 03:44 PM
Bob Gervais's Avatar
Bob Gervais
That 95 is going to have the same components as your 96.
As far as a solid axle being better, that all depends on your planned usage of the truck. Want huge tires, and go off road a lot? Solid axle is the way to go. If your plans don't include those things, a solid axle isn't going to be a worthwhile mod for you.
Old Mar 31, 2014 | 06:00 PM
rla2005's Avatar
rla2005
X2
Old Mar 31, 2014 | 07:38 PM
Roger T. Pipe
Thanks for the points, guys...yea, I don't think that I'll even have a change to make it there to see it, so you saved me some time!
Roger
Old Apr 3, 2014 | 08:32 AM
garthneddy's Avatar
garthneddy
If you had the coil sprung TTB then I would agree with the above posts, but since you have the leaf sprung variant I would say a solid axle is better.
The coil sprung TTB has the ability to allow the axle beams to travel in an arc without resistance. The leaf springs are forced to twist on the F250s during the axle beams travel, which causes premature wear on the springs and front suspension bushings as well as severely limiting suspension travel.
Even if the truck is used on road, you will have much longer component life and better ride quality.
Holdmybeer
Feb 15, 2019 05:33 PM
M.Farragher
Jan 17, 2019 12:21 PM
fbavaro1
Oct 30, 2011 10:27 PM
doug6644
23
Nov 4, 2009 06:19 PM
Chris_ce
Feb 20, 2004 03:51 AM
