Need Help 99 Expedition
The kit arrived this evening, well packaged and included a nice laminated set of instuctions.
I took a quick look at it and was very impressed. The kit comes with everything needed to do the job and 5 inserts. I already have the new coil and sparkplugs so now i just need the time to do the job.
I won't have time to install the insert until this weekend. While i'm doing the insert i decided to replace all the sparkplugs, i figured since i'm in there i might as well check everything. The last thing i need or want is another one failing. I'm just hoping i don't find more the 4 other failed sparkplugs (that would require ordering more inserts!) hehe
I'll post some comments on the job once it's all done.
My big question here, is it preferable to use the standard Time-Sert kit, or the Big-Sert kit. It seems that the time-sert kit would be easier to install, mainly because I don't have to cut away so much metal. I don't care about using full-thread plugs, plus it's cheaper. Is there anyone who has used the standard kit and can testify how well it works? All rhe reviews of the Big-Sert kit are excellent, so I may just do that anyway.
Also, can you just buy a new boot for the coil pack, or do you have to buy the whole thing? Mine got jammed under the fuel rail, and didn't go anywhere, just the boot split down the side.
Aaron
I did the insert first and then replaced all the sparkplugs. The insert job went well the "T" handle for the reamer and the tap are about useless though due to clearance issues. I ended up using a ratchet instead. Intial reaming of the hole took me the longest. I ended up attaching a right angle drill to the reamer bit to finally get it finished. I got to a point reaming that i just wasn't making anymore progress so i decided to give a powertool a shot at it and it worked great.
Clean-up wasn't bad at all. As recommended in the instructions i packed the flutes with grease and when i was done i used a small tube attached to my shop vac to remove any remaining metal slivers (which were minimal).
I'm happy with the kit overall. Great instructions and everything needed to do the job right so IMHO it was well worth the price.
Wife is back on the road so she's happy and i have some new tools to add to my collection.
A BIG thanks to everyone on this forum who helped me with this, your assistance was top notch.
Granted it's a known issue that these heads have problems so sure it's Ford's fault. There are also plenty of Expy's out there that don't have this problem. Without knowing if the sparkplugs were properly installed there is no way to know what actually caused the problem it could have been the origional owners fault, Ford or both.
Improper installation of sparkplugs just increases the chances of failure on a already weak design.
Porbably a 2000 - 2002. I was looking at getting the 5.4 liter engine;
I need to tow a race car every once in a while.
Did Ford redesign the heads on the 5.4 to solve this problem? Or is this
something I'm going to have to worry about when/if I go with the Expy?
thanks
msautry
