Cap and rotor conversion
Old Dec 27, 2004 | 11:32 PM
Big Dave's Avatar
Big Dave
Question Cap and rotor conversion
I have seen several posts here about swapping to a bigger distributer cap, rotor and bigger wires (not recently though), but haven't been able to find the specifics involved.
Is this applicable to my '75 390 w/ electronic ign? What parts do I need to ask for to make this work? I want to do this to make the best use of an Accel Super coil that I already have.
I recently found a crack in the current cap, so this would be the time to do it. Are the lifetime warrenty Bosch wires any good?
Thanks,
Dave
Old Dec 28, 2004 | 01:22 PM
Six Niner's Avatar
Six Niner
hey dave you just need to ask for a late model cap, rotor, and cap adaptor. something from a late model 302 or 351 (it still fits). ive done the same upgrade to mine. as for the bosch wires i dont know, ive got the premium napa set on mine. good luck.
Old Dec 28, 2004 | 04:11 PM
cleanLX's Avatar
cleanLX
cap, cap base and rotor for an '85 Mustang 302 is what I ended up with.
I went with Ford Racing wires for a '92 Mustang 302.
Old Dec 28, 2004 | 05:20 PM
76supercab2's Avatar
76supercab2
Hmmmmmmmmm. Try this link:
https://www.ford-trucks.com/article/...rge_Cap_8.html
Old Dec 28, 2004 | 07:11 PM
ford390gashog's Avatar
ford390gashog
the only reason you would need a bigger cap is if you were getting spark cross over or runnning a msd or other aftermarket ignition
Old Dec 29, 2004 | 05:51 PM
Big Dave's Avatar
Big Dave
76supercab2, Thanks for the link, that is exactly what I was looking for.
cleanLX, Were the wires for the 302 long enough for the FE?
Thanks for the help guys!
Old Dec 29, 2004 | 10:57 PM
cleanLX's Avatar
cleanLX
Yes.
Had a new set waiting to go on my Mustang, and thought, what the heck.
They fit like a glove.
Old Jan 23, 2005 | 06:25 PM
Big Dave's Avatar
Big Dave
I just bought a spacer, Accel cap and rotor for a 90 model 5.0 mustang. The problem is the rotor doesn't come close to fitting the distributer shaft and the spacer has 2 screws to hold it on the dizzy. The link in the post above used the clips on the dizzy to hold the spacer on. My dizzy looks exactly like the one in that link. Did I just get the wrong parts or what?
Old Jan 23, 2005 | 09:37 PM
cleanLX's Avatar
cleanLX
the cap and rotor for my '92(same as '90) do not look the same.
Good luck
Old Jan 23, 2005 | 10:58 PM
Putt's Avatar
Putt
Dave, you got too new of a cap and rotor. Those are for a TFI type distributor that has no advance, the distributor is different. Get a cap and rotor for the year cleanLX said.
Old Oct 15, 2008 | 03:15 AM
drfelgood5's Avatar
drfelgood5
Problem around here is that junkyards that stuff gets snatched up right away. What year could you get brand new at the parts store and can you recomend a possible brand, also a type of plug wire and plug to complete ethe set. Im in dire need of a tuneup and i have the buzzing in the radio that gets louder as the engine reves higher.
Old Oct 17, 2008 | 10:36 AM
manglass's Avatar
manglass
The parts you need fit a wide variety of years (77-?) and models (all) with the 302 engine. Following is one sample that should work:
Application: 1977 F-250 w/302 (5.0L) engine
Distributor Cap - Standard FD168 (aluminum terminals), FD168X (copper terminals)
Cap Adapter - Standard FD156
Rotor - Standard FD117 (reg. grade), FD117X (high grade)
Spark Plug wires - Standard 6880, AC-Delco 16808U, Bosch 09771
As for spark plugs, get whatever set fits your truck. I have not had good luck with Champion or Autolite. Motorcraft, AC, NGK, and Denso have worked well for me. YMMV. It is possible that you might have to adjust one heat range up or down after you make this change. If you do, keep within the same brand as different brands of spark plugs seem to have slightly different heat ranges for the same application.
Good luck with the switch, it should be beneficial but I didn't really notice any difference when I changed mine.
Lou Manglass
Nightrain
Jul 14, 2004 03:06 PM
Dave85zxt
Feb 22, 2003 10:30 PM
geevoor
Oct 14, 2002 02:11 PM
jimandmandy
15
Sep 14, 2002 10:16 AM
rick1989F350
Jul 30, 2001 08:54 PM
