changing all fluids
Old Dec 27, 2004 | 12:49 AM
muddyford75's Avatar
muddyford75
changing all fluids
i think im going to take the time and change all my fuilds in my 75 f250 4x4
any advice would help. do i have this correct
transfer case- 90w?
transmission- tranny fluid
front and rear dif- __________
closed knuckle ball joints- grease
powersteering box- grease
radiator- 50/50
oil- 10-40
am i forgetting anything? if so please add and write what i should replace it with.
thanks
Old Dec 27, 2004 | 12:53 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
If it is an Automatic ? make sure to use type-F tranny fluid,
i used a dextron brand that claimed to be ford friendly in my power steering and tranny, started my truck and didnt have power steering anymore, and my tranny started slipping.....i had to purge all that fluid out and refill with type F to get it going right again....i dont know what the big difference is, but its there for sure.......
C6's used Dextron fluid
Old Dec 27, 2004 | 01:17 AM
FmrFrdTech's Avatar
FmrFrdTech
Brake fluid flush - Dot 3 or better (requires bleeding system)
Old Dec 27, 2004 | 01:58 AM
ftballman125's Avatar
ftballman125
hey collin ive got all the info we need...but you do not use tranny fluid...youve got a manual so you will use the same fluid for the trans case and the tranny...ill show you the list later on...just dont want you to pick up any type F for the tranny...Type F we will use for the power steerin.
Nick
Old Dec 27, 2004 | 02:56 AM
SwOkcOffRoader
manual?? yeah, you shoulda said that.......
Old Dec 28, 2004 | 08:30 PM
rakent's Avatar
rakent
FYI, here are the specs from my shop manual for my '74 F250
SAE 50w engine oil for the NP435 4spd transmission and NP205 transfer case (30w in cold temps)
SAE 140w gear oil for the Front and rear differentials, knuckles
Type F fluid for the power steering system
45/55 antifreeze mix for the radiator
SAE 90 EP for the steering gear
SAE 10, 20, 30 & 40 single viscosity oils for the motor, depending on temps
SAE 10w engine oil for light duty work, multipurpose grease for the chassis
For what it's worth, I'm running 85w140 in the axles, a 50/50 mix of 85w-140 and Lucas Oil Treatment in the knuckles to keep them from leaking, and 75w-90 in the tranny and transfer case because I can't find SAE 50w engine oil.
j66b
1997 - 2003 F150
17
Oct 5, 2014 07:57 PM
oldtimer50
May 16, 2010 07:31 PM
maa139
Garage & Workshop
Jun 4, 2005 07:11 AM
MrBadExample
Mar 3, 2005 11:09 PM
Munkey
Jan 17, 2005 09:52 AM
