Sponsored by: Real Truck
Front Diff. Oil Weight / Greasing Poly Mounts
Old Jan 17, 2005 | 02:54 AM
Munkey's Avatar
Munkey
For my '02 with the D60 up front, the manual calls for 80w90 lubricant. Being totally obsessive, all the replacement fluids & lubricants in my truck must be Mobil1 or I will lay awake at night thinking about it. Mobil1 offers 75w90 gear oil, which I'm sure is just fine to use. Whats the main difference between 80w90 and 75w90, and what problems might come up from using it?
I've always heard you need to grease new poly bushings or they will squeak like crazy. I'm about to swap out my OEM body mounts with a set of Daystar poly mounts (OEM's are creaking & popping like a bowl of Rice Krispies). What kind of grease should I use? Regular wheel bearing grease such as the Mobil1 I've got in my grease gun? Or maybe white lithium grease, or silicone grease??
Old Jan 17, 2005 | 09:52 AM
wlihntr's Avatar
wlihntr
the 75-90 will be a little thinner when cold, but at operating temp they will be the same
SpringerPop
147
Aug 6, 2015 02:16 AM
MikeTEC
Oil & Lubrication
Feb 12, 2014 06:38 AM
ManfredVonRichtofen
1978 - 1996 Big Bronco
Feb 17, 2013 02:55 AM
ron's power stroke
23
Oct 10, 2006 04:22 PM
Just Chuck
All Things Towing
21
Jul 10, 2004 08:29 PM
