eot mod, clamp mod, TIP-MAP swap
Old Feb 6, 2005 | 09:48 PM
  #31
89ford73's Avatar
89ford73
ok, so you just made it to whereit goes to the end of the rheostat and no farther? becaust hten i guess it would be just dead in the water right?? what if you just hooked up a hotwire from a switch to the output and hooked it to a switch??? 12 volts instead of 6? would that work. i dunno, i guess i could get out the multimeter and see which wire comes from the rheostat and hook a wire up and see if the engine revs up... i guess it's worth a try. does anyone know of a way to increase governed speed of the engine to 4,000 instead of 3300??
Old Feb 6, 2005 | 10:21 PM
  #32
444dieselrod's Avatar
444dieselrod
I wouldn't try the 12Volt idea until you know exactly what voltage it works at, put 12 on the rheostat and you might fry it, 12 into the output to the pcm, same thing toasted pcm. I dont remember what wires where the input, output, and common for the rheostat, I had to play around with it on the table for a while.
Hold the tranny in 2nd and it will rev to 3500, then shift pop it into 3rd shifts REAL hard. At least thats what mine will do with the T/C mod, really snaps the neck back, pretty sweet. not good for a stock tranny though. But I too wanna know, what are some of these guys seeing for rpm's, anyone hit 4G's yet???
Diesel Rod
Old Feb 6, 2005 | 10:32 PM
  #33
89ford73's Avatar
89ford73
i know i can get the ol' i.d.i. to 4,100 in neutral floored. and i can hit a whopping 75 mph in 4th gear at 4,000 with the 4.10's. i sure am glad i got the 5 speed overdrive! but i know if the ol' idi with 340,000 miles and 4.10's can do it, that a powerstroke surely can handle it!
Old Feb 6, 2005 | 10:34 PM
  #34
89ford73's Avatar
89ford73
p.s. i had the pump guy do a little tweaking during the rebuild sure does run good. and it pulls hard all the way to 35-3600. i think it just runs out of air at that rpm. (lotsa smoke)
99ExpyProblems
Sep 1, 2018 07:45 AM
ryobi1
Sep 21, 2016 01:30 PM
fordpride
15
May 23, 2016 01:00 PM
fordpride
Jun 26, 2012 10:49 PM
WhiteBeast-05-powers
Sep 16, 2011 07:18 PM
