Got a problem with my 84 Bronco. Headlights will work fine until they heat up, then both low and high beams will constantly flash on and off. I will turn them off and let them cool, and they will work fine. Don't know what to do!
Change the headlight switch. There's a circuit breaker in the switch. When they get weak, they open & close, open & close, etc. etc. etc. While you're changing the switch, you will probably have to change the connector also--they always overheat & melt. Most auto parts supply stores can get the connector.
yea thanks to this post i figured out that was the problem with my 1993 bronco. Thats really wierd is it supposed to get that hot and if so, anyone know why ford didn't recall the probelm?
