Does computer lose its settings when battery disconnected?
Old Dec 26, 2004 | 06:58 AM
buckarooboy's Avatar
buckarooboy
need to disconnect the battery briefly on my 05 expy. does the computer lose its settings? how could I avoid this? thanks
Old Dec 26, 2004 | 08:40 AM
myankow's Avatar
myankow
Having 2 batteries would keep everthing saved, but pulling out the manual to reprogram everything has always been standard procedure. (on some older cars i have encoutered the radio will not operate unless you key in a radio code after battery disconnect----I guess that was their way of making stolen radios useless-because no-one would know the code except the owner with the manual)
Which computer? Typically any computer will reset to the default settings. The ECM (Electronic Control Module) is a dynamic device that adjusts the air/fuel spark/ timing to current conditions like engine temp, ambient temp, barometric pressure, to name only a few. So it needs a starting place (default settings) in which to begin ignition/starting sequence until it gathers the data and responds accordingly.
On other internal memory storing modules in the car you will loose programmed radio stations, seating memory positions, alarm lock settings, gas mileage accompishments, door lock codes?etc.
Old Dec 26, 2004 | 11:52 AM
oasebastian's Avatar
oasebastian
One way of not losing any of your setting is to hook up a battery charger to the negative and positive wires going to your battery. Just be careful that is does not get disconnected while it is disconnected from the battery. Get some electrical tape to hold it in. I recently had my battery replaced on my 97 expe and my remote door locks did not work until I drove the drive for a little bit. In general, car computers reset itself once you start driving it.
Old Dec 26, 2004 | 07:16 PM
03EBExpy's Avatar
03EBExpy
I literally just read about this but can't give you much detail as I don't have enough details myself. The basic factory settings will be fine but you will lose some programmed functions (I'm sure this is what you are concerned with). You can buy a battery backup (gizmo that hooks up through accessory adapter), 9 volt, I believe, that will keep all functions in memory, including radio preset, door codes, etc. I am looking into more detail as I write...
Will post as soon as I figure it out. Anyone else, post up if you know what I am talking about....
Mark
franky5
1997 - 2003 F150
Jan 25, 2016 09:05 AM
franky5
1997 - 2003 F150
Jan 22, 2016 06:46 PM
Rob Ert
Aug 15, 2015 07:11 PM
jeffdoerr
26
Oct 3, 2009 01:32 AM
VPS
Jan 21, 2003 01:39 PM
